The "Help NismoPick get his Z home" Thread
Old May 8, 2007 | 12:26 PM
  #51
Just received a phone call from my dad... the z has arrived at my garage.
Old May 8, 2007 | 12:46 PM
  #52
lifegrddude's Avatar
Externally Wastegated
Glad your Z made it back safely dude! Hope you get it fixed and back on the road soon!
Old May 8, 2007 | 12:50 PM
  #53
Much thanks to those that helped w/ advice, contributions, and tech support in this crappidy time. Woot!
Old May 8, 2007 | 01:03 PM
  #54
if I still had that extra P90a head I would send it to you... but it sold
Old May 8, 2007 | 01:32 PM
  #55
I'll prolly use parts from my spare P79... are the rockers for P79 & P90 the same?
Old May 8, 2007 | 02:19 PM
  #56
what is the issues though, the cam and towers or just the cam???
but yes, the rockers and cam should swap over.
Old May 8, 2007 | 02:29 PM
  #57
The cam for shizzle... I'm not sure about the towers (I'll find out when I yank the cam)... and I imagine the rockers too. I would assume if the cam lobe got ground down, it did some damage to the rocker face too.
Old May 8, 2007 | 02:37 PM
  #58
both sides of my rear right rotor are ground down. Do you think I should replace the brake pads?
Old May 8, 2007 | 02:46 PM
  #59
Well now you're just being silly!
Old May 8, 2007 | 07:47 PM
  #60
hey make sure to replace all the stuff in there. rockers, cam and towers. it will all be a mess. i got spares of stuff, but as for the rockers, if they didnt get numbered coming off the exact cam, youll have to buy new, or they will always clatter and make noise. dont ask how i found that out.
Old May 8, 2007 | 08:58 PM
  #61
Yeah, everything will be replaced reinstalled in correct order.
The car is home... The transporter was actually a double decker semi so they had to leave the car on the street. I started it & drove it into the garage... so it still runs, and even pumped oil to the cam... now I really don't know what the prob is.
Old May 8, 2007 | 09:15 PM
  #62
you touch yourself at night..... no lol, yeah idk well, start it and listen.... and look, only thin i could think of;
Old May 9, 2007 | 06:52 AM
  #63
the car came off the carrier at a steep angle correct?? it could be your pickup is broken or clogged, so when it was put at an angle, it was able to suck some oil that was around it. bit far fetched, but ive seen weirder things happen.
Old May 9, 2007 | 12:37 PM
  #64
thxone's Avatar
Here is the exact problem....you have a piece of something floating in your oil pan...this "thing" gets sucked up to the pickup screen and blocks the oil...when the car is turned off pressure drops as well as the "thing"....when the car came off the truck the "thing" moved away from the pickup tube and screen and now you have oil to the top of the engine....be warned...it will get sucked up again. When you find this to be true...post what it was so everyone will know I was right.
Old May 9, 2007 | 01:17 PM
  #65
Yeah... I'm prolly going to flush it really good w/ some ATF & use some new oil, prolly synthetic. Then just check how well the cam is receiving oil. I really don't want to drop the oil pan to check the pick up.
Old May 9, 2007 | 01:23 PM
  #66
thxone's Avatar
Get a real strong magnet...doesn't have to be big and put it on the outside bottom rear of the oil pan...if it's a metal shaving "thing" then it will hold any metal to the magnet...works on auto tranny too...inside or outside of the pan.
Old May 9, 2007 | 02:36 PM
  #67
the pickup has a large screen over it. That thing would have to be a pretty big chunk of plastic to block the oil pickup. From there the oil goes to the pump and the guage showed good pressure. I would say the problem lies in the head or cam itself.
Old May 9, 2007 | 03:38 PM
  #68
thxone's Avatar
Yeah, true. I bet it's cause it's a 2+2 J/K
Old May 9, 2007 | 04:09 PM
  #69
RodMoyes's Avatar
Doesn't post much...
I'm thinkin' it's because his wheels are too small...
If he at least had some 17's on there he'd be OK
Sorry, couldn't resist.
Rod.
Old May 9, 2007 | 06:04 PM
  #70
yeah, you mightve goten **** up in there is all, just do what you said do teh nice ATF flushing (does wonders) and make sure its coming up through to teh head and then change it back out. and see whats up.
Old May 9, 2007 | 08:35 PM
  #71
z-hag's Avatar
Queen of Yachts
hay, dont fergit to change out the indestructible oil pump that only lasts 200k miles.............
Old May 10, 2007 | 06:48 AM
  #72
put msa's high pressure springs in it. if one of those is weak, it wont get oil all the way up the motor. the pump may be fine, but the springs are allowing it to bypass the pump a little. those springs are only worth 5 bux err something.
Old May 10, 2007 | 09:07 AM
  #73
Just pack about four little springs in there so you get 130psi oil pressure and run really thin oil. See what that does!
Old May 10, 2007 | 06:35 PM
  #74
z-hag's Avatar
Queen of Yachts
If he at least had some 17's on there he'd be OK Sorry, couldn't resist.Rod.
sorry, guyz--after rethinking this one, i think i am gonna have to go with rod on this one----nis, baby--get a witch and do whatevwer she/he has to say on this subject.....yer car is possessed and needs bigger wheelz.........sorry......aint nottuin else makes sense,,,,,
Old Jun 23, 2007 | 06:39 PM
  #75
Today I had time to work on the Z (first time that I've even wanted to work on it since MSA).
Pulled & swapped cams. Pics of the damage:
Opened up the rocker cover... oh what's that? One of the rockers not even mounted:
Carnage of the cam:
