get more hp on my 280zxt
Old Jan 14, 2011 | 11:10 PM
datsun280zxt's Avatar
i have a 1981 280zx turbo with t5 trans. have a stage 3 clutch, intercooler and piping.. what will be a good fuel pressure and injectors to put the stock boost from 6/7psi to 10/15lbs.. and would it be better to get a different turbo or get a rebuilt original turbo.. or any other suggestions to increase hp on my 280zx thanks
Old Jan 14, 2011 | 11:38 PM
Tune up. anything more then stock and you need custom EFI management, bigger turbo, bigger injectors, downpipe and exhaust to accommodate the bigger turbo...etc If you want to go the easy route, you could go with the z31 EFI swap and be safe to about 10psi and gain the benefits of a MAF.
Old Jan 15, 2011 | 07:22 AM
You can run 10psi boost on a pure stock setup. I actually can't believe you installed an intercooler and you're still running stock boost.
Old Jan 15, 2011 | 07:56 AM
fuel pressure stays the same, you just need more volume. for now stock is fine, it will keep up. on a stock ecu upgrading the injectors just wont do much. the ecu cant control it at all.
Old Jan 15, 2011 | 10:00 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
HKS T51R
The stock turbo is good for import power in its day, but you gotta step up in the world.
Old Jan 15, 2011 | 11:38 AM
well actually when i installed the intercooler i am running 9lbs. but i want it at 15lbs..
Old Jan 15, 2011 | 04:31 PM
Electronic boost controller, walbro 255, larger injectors
and you need a larger turbo, the stocks will not put out much higher than what you're looking at
even my rb20 stops putting out at like 9lbs stock
Old Jan 15, 2011 | 05:05 PM
It isn't even so much that the stock turbo can't put out that amount of boost, but it will be very hot and innefficient. And you get the chance of the boost dropping in higher RPM range. Also, if you want bigger injectors and run 15psi and make use of it, you most likely can't use the stock ECU setup anymore. Go standalone or like hoov said go Z31 ECU swap, then you can even get nistune on it for tuning.
Old Jan 15, 2011 | 07:35 PM
http://nistune.com/equipment-products-type1.php
440AUD = 435.38USD
Expect to spend a pretty penny making your L28et push to what you want it to
Old Jan 17, 2011 | 02:43 PM
Convert to RHD and get an even BIGGER turbo!
Boost until you throw a rod, like JDM, yo!
Old Jan 17, 2011 | 03:00 PM
pete8717's Avatar
Who needs to convert when you have the real thing? lol
Reptile00Seven
Dec 22, 2011 02:25 PM
mayitin
Nov 30, 2008 07:14 AM
918v_zxt
Jan 24, 2008 10:01 PM
jjohart
Nov 26, 2005 10:48 AM
280 drooler
Jul 16, 2003 11:48 AM
