Gasket stuff
Old Mar 10, 2009 | 10:13 PM
BlueKitsune's Avatar
Intrawebz Wizard
Gasket stuff
Ok Im replacing the timing cover has most of you know but Im not sure if I also have to replace the oil pan gasket as well and is the upper part part of the head gasket? I do NOT want any oil leaks on an engine with only 6 miles that I may swap out here soon.
Also do they make rubber valve cover gaskets? So I can just reuse them after messing with the valve lash.
Old Mar 10, 2009 | 10:20 PM
i got a rubber and non rubber VC gasket before, you should replace the oil pan gasket when you remove the timing cover, but i think inorder to do that in the S130 you need to lift the motor up some, in the S30 with the manual rack you could squeez the pan off without touching anything else. the head gasket should not matter at all.
Old Mar 10, 2009 | 10:25 PM
Intrawebz Wizard
Hmm Alright. Thanks! And I think I can get that pan off w/o lifting the engine. ... Figured it has brand new oil in it and I have to take the pan off... Go fig huh?
Old Mar 10, 2009 | 10:36 PM
straight hate's Avatar
Yeah, what Snwy said, gotta undue the mounts and hoist it up...You can always try losening the oil pan, dont drop the bolts, just loosen it up, 50/50 shot if its gonna leak or not. Gouge the gasket and you will end up replacing it anyways. If you go to that much trouble I would replace it anyways, along with the motor mounts, and on and on and on...I never replace my VC gasket after any kind of adjustment etc. You should be able to get it off aand on a couple of times before you have to replace it.
Old Mar 10, 2009 | 10:38 PM
Intrawebz Wizard
My current VC gaskets it literally cut up, and all the mounts are new BTW well new as it they only have 6 miles on it lol And Im just gonna drain the oil, It was cheapy oil my friend put in anyways I think it was like...pensoil? idk
Old Mar 10, 2009 | 10:42 PM
If the VC fuct, its fuct. I usally buy OEM (got a hookup)and you can usally get a couple of valve adjustments out of it before its shot. I think I have a bad HG and I HAVE to do a timing chanin while I have the head off so I'm probally gonna be in the same boat as you Blue.
Old Mar 10, 2009 | 10:49 PM
Intrawebz Wizard
OEM? You mean Nissan still makes parts for these cars besides the gas cap? lol Thats neat. The HG On these Zs dont look hard at all a shop crane would make it a snap for sure
Well good luck with your HG! I just want my Z engine to run again! 6 miles isnt bad, sitting for 6 years IS bad
Old Mar 10, 2009 | 10:54 PM
LOL! Yeah...spark plugs and gaskets, HA!. It just takes weeks/months to get any of stuff you really need.
Old Mar 10, 2009 | 11:01 PM
Intrawebz Wizard
Er thats too long for me lol I'll stick with the Felpro ones I can get at my work that I get withing a few days if its not already there lol along with my employee discount! I actually might buy a few engine gasket kits, their not that much I think
Old Mar 10, 2009 | 11:19 PM
dont get me wrong now. Gaskets, spark plugs, and easy stuff are generally there 2-3 days. Anything bigger, it might take a while. I ordered a OEM oil pan a couple of years ago and it took 3 months!
Old Mar 10, 2009 | 11:25 PM
Intrawebz Wizard
Wow, tho parts like that are hard to find. Can you get OEM Body parts?
Old Mar 10, 2009 | 11:37 PM
I used to be a grease monkey at a dealership but they let me out of the cage. You can still get quarter panels, OEM weather stripping and all that, Its just going to cost you. I checked on weather stripping once but it ran about $200. per side, and that was with a discount! I'll keep my leakey tops for now.
Old Mar 10, 2009 | 11:55 PM
Intrawebz Wizard
wow... ouch ya I think I'll try to find after market body panels...
Old Mar 11, 2009 | 12:33 AM
lol, i just thought of the movie old school "YOUR MY BOY BLUE!"
Old Mar 11, 2009 | 01:03 AM
Intrawebz Wizard
uuuhhhmmm What?
tmcharper
Jul 29, 2009 04:45 PM
Warpix
Jun 11, 2009 09:19 PM
User395
Feb 19, 2009 08:03 PM
AllmyZs
Oct 26, 2004 08:44 PM
wickedshadowz
Jul 20, 2002 05:42 PM
