Fuel Rail Install Jsk
Old May 13, 2005 | 12:53 PM
81 Black L28E's Avatar
so everything seems to be coming together for my injector install i got my injectors and clips i EBAYED a JSK fuel rail ... has any one installed a jsk fuel rail befor i would like to see pics of it.. if so iam still not sure on a few things like gas tank return ..is it ok to run a piece of BRAIDED hose from the end of the rail back to the tank return ,if so making a longer hose from the out ?? ALSO MOUNTING MY REGULATOR is it ok to hook it right at the begaining of the rail just after the fuel fliter.. i really need to see a pic of this set up
Old May 13, 2005 | 01:50 PM
I sent you a message with a bunch of links to JSK installs.
Old May 13, 2005 | 04:38 PM
s/cL3.0's Avatar
Bleach is my Hero
I would appreciate that as well.. I will more than likely be getting a JSK fuel rail to.
Old May 13, 2005 | 04:57 PM
Skully's Avatar
i just got mine but its anodized black
Old May 13, 2005 | 05:55 PM
Heat Rave R's Avatar
Yeah, could you post the links here; I'm considering getting one too!
Old May 13, 2005 | 06:57 PM
JSK 1 JSK 2 JSK 3
JSK 4 JSK 5 JSK 6
Not the absolute best pics for installation instructions, but it gives you the idea.
Old May 13, 2005 | 06:58 PM
That's because you joined the dark side...
Old May 13, 2005 | 07:49 PM
Skully's Avatar
yesh yesh..hehe...i think only thing that will be shiny under the hood is the valve cover..unless i do that in black too...but then its got no show appeal :P
Old May 13, 2005 | 08:29 PM
http://www.msdignition.com/fuel_7.htm
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
http://www.cartech.net/fmu2020.htm
http://www.redlineweber.com/html/fue...regulators.htm
WITCH ONE OF these ragulators WILL DO? I LIKE THE SPENDY ONES BUT I THINK THE LAST LINK WILL DO ....ANYONE HAVE ANY THOUGHTS
ok i think i got this set up fig out THANKS to BLEACHZ ALWAYS KNOWING WHAT TO DO....... the only thing iam not sure of is the ragulator.. {WHAT KIND} I think i want it right at the start of the rail ,,, iam going to do fuel in at the front TO fuel out at the back style.. my wires that come out of my NEW clips are extra long so i think i can cut my harnees right at the OLD clips and make my harness longer so that it will go around the back side of the rail along the val cover to each injector ..i realy think that style is the best looking.. YOU GET MORE VIEW OF THE RAIL
THANKS FOR ALL YOUR HELP AS ALWAYS BEACHZ
Old May 13, 2005 | 10:14 PM
Don't you put the regulator on the output side of the rail? It holds pressure inside the rail and releases fuel as needed back to the tank.
I like this one the best. This one is what I plan to buy, but for turbo engines.
Old May 13, 2005 | 10:17 PM
DarrellBuddy321's Avatar
how does the fuel rail mount? Does it screw into the old spots or does it hang off the injectors? I couldnt tell in the pictures
Old May 13, 2005 | 10:24 PM
I THINK SOME PEOPLE LEAVE IT HANG AND SOME PEOLPE MOUNT IT OFF THE SPOT WHERE THE OLD ONE MOUNTS
Old May 13, 2005 | 10:26 PM
YES THAT ONE IS NICE BLEACH BUT WITCH ONE IS FOR NA? CARS
Old May 14, 2005 | 01:16 AM
IF this is so then why is it that on the stock rail the ragulator is the frist thing after the fuel filter.. i also found some pics.......................... in the frist pic ,, what is the black tube in between the front of the rail and the tank return... this pic shows that he ran the regulator frist into the back of the rail and then out the front into the tank return.. i have seen this little tube in other pics look closely is it some kind of fliter going in to the tank return
also one pic of a sick body style does anyone know what company these body pieces come from... i think he modded them from a kit that goes to a diff style car nice work diff from everything i have seen
Old May 14, 2005 | 02:10 AM
You don't know the power of the Dark Side! LOL!
Old May 14, 2005 | 11:39 AM
On the stock fuel rail, the regulator is last. The rail is a circle as you know and the entire rail is pressurized. The one spot where the fuel goes back to the tank is where the regulator mounts. The fuel has to go through the regulator to return to the fuel tank. The regualtor regulates how much fuel it will let back to the tank and that is what keeps pressure in the rail itself.
So if you follow the fuel lines, and your fuel filter goes to the line that feeds into the regulator first, then you have your fuel filter on the fuel return line!
Old May 14, 2005 | 04:38 PM
yes i see now ihow it works.... i went looked over mine again but witch one should i buy ....ragulator that is .......
Old May 14, 2005 | 05:23 PM
Skully's Avatar
i got an aeromotive a1000-6...ive heard its great for turbo aplications....you wouldnt need anything more than a stock rated one...
Old May 14, 2005 | 06:05 PM
so if i just buy a stock one then iam golden.... just mount it after the rail befor the tank return and she should work like a charm....... i really wanted a cool looking one that was for stock useage... iam running 190cc python injectors {not 550cc but iam stoked}
This one is really nice BLACK AND RED ..will it work for my stock setup...
http://216.242.145.16/products/product.phtml?p=12
Old May 14, 2005 | 08:09 PM
For non-turbo apps such as yours you don't need anything special. Just pick one based on looks and price I guess...
http://store.summitracing.com/egnsea...053+4294880914
Old May 14, 2005 | 08:13 PM
Skully's Avatar
yes dont forget..dont get the the one for carburated engines...:P
i got the one on the top of the list
Old May 14, 2005 | 08:14 PM
Skully, pick one out for him that's red.
juggalo280ZX's Avatar
check your pm skully.
Old May 14, 2005 | 08:20 PM
Skully's Avatar
haha Bleach..i was gonna pick him out a nice pink one...
Old May 14, 2005 | 09:26 PM
you still can
