ok so im thinking of some ideas on what to do to get my engine to around 200hp. im staying n/a and i want to keep it a daily driver.
now i want to raise the compression to about 9.5/1. i was wondering witch would be a better way to do it, oversize the pistons or to deck the head.
my other question is on my head can you clean out the exhaust ports to get rid of the round tube thats in there.
thanks
thanks
Shady is runnin ~200hp on his L28 n/a... he built that thing like a rock.
< gets out intraweb p.a. > SHADY!!! Tune in to this thread....
Basics:
Lots of head work (decking, valves, porting)
Mild cam
Header w/ 2.5" exhaust
60mm throttle body & turbo with n/a guts AFM
Upgraded ignition
Basics:
Mild cam
Upgraded ignition
ya that is basicly what i was looking into doin. so if i leave the bottom end alone and just work on top end 200 would not be hard to do, just time and money
Haterade by da gallon!
wouldnt he need to port/polish the intake manny and bigger injectors? (unless those were a given)
EDIT: nm he's only going for 200 and the comp increase should about cover that... (up your goals
)The Good Twin
Quote:
You may have missed this:Originally Posted by 280zx2by2
Quote:
polishing an intake is overkill. You want the air to flow unrestricted, but a slight agitation of incoming air actually helps the air / fuel mix.Originally Posted by NismoPick
Quote:
to get the fuel to further vaporize?Originally Posted by NismoPick
i would up my goal but i dont feel like putting that much money into the stock n/a set-up. rb25 will be going in once i get a good paying job and have time to build that up.
what exactly does that ecu change?
Quote:
The flapper AFM will change to a MAS. The fuel metering system is much better and the ECU then controls ignition timing by using a distributor from a 280ZX turbo and the crank angle sensor from a Z31 is placed into that 280ZXT distributor.Originally Posted by scorpionp54
Plus once that is in place you get basic "codes" from the ECU if there are issues. Its not an amazing fuel management system but much better than the ECU used from 1975-83. (plus its cheap to buy the parts)
1988-89 Z31 even has 2-bank injector firing! High tech!
This Just in!
I just got a tip from NismoPick that a 240Z ECU also adds 12hp. I'm still trying to find one though. I guess they are super rare...
i will definetly look into doin that.
so here is what i am planing to do
mild cam swap,
port polish head,
raise compression,
z31 ecu swap,(and everything else that goes with it)
60 mm tb,
5 speed tranny swap,
upgraded fuel rail,
headers, 2.25 exhaust,
remove a/c system
then back to what i asked first to raise the compression is it better to just deck the head or oversized pistons
mild cam swap,
port polish head,
raise compression,
60 mm tb,
upgraded fuel rail,
remove a/c system
Quote:
Better? In what ways do you mean?Originally Posted by scorpionp54
I say... Plug it in, plug it in
http://www.ozdat.com/ozdatonline/enginedesign/
http://www.atlanticz.ca/zclub/techti...der/index.html
http://www.zonc.org/TechnicalInforma...binations.html
your 240 didnt come with one? Originally Posted by Bleach
This Just in!I just got a tip from NismoPick that a 240Z ECU also adds 12hp. I'm still trying to find one though. I guess they are super rare...
i guess better as in a more reliable setup,
now after loking at those links im thinking more into an oversized piston, i looked at the msa pistons, but they showed they dont show any in stock. where else would i get them?
ok thanks. i'll look around at the machine shops in my area thanks for the help.
