Custom Fuel Rail Specs???
http://www.injector.com/fuelrails.php
http://www.freewebs.com/pallnet/products.htm
It really depends on which injectors you will use.
Originally Posted by Pallnet
L28 O-ring rail…This is a conversion rail, hoses and holders are not used.
11mm Smooth ........$105.00Make payments with PayPal - it's fast, free and secure!
This for your DSM, Early Supra and RX7 Denso style injectors.
14mm Smooth.......$105.00 Make payments with PayPal - it's fast, free and secure!
This is for most of your Ford and some GM Bosch style injectors.
Sorry... I had to cut that previous post short. I wanted to say:
If you use the stock barb'd injectors, just get the NPT fittings & have the injector ports bored & tapped to screw them in. Do the same for both ends of the rail (for in and out). I believe the normal bore through the middle for fuel flow is 1/2 or 3/4 inch. You can always email Pallnet at pallnet@hotmail.com and ask him more about his rail.
