Cork or rubber A/T gasket
Old Nov 9, 2012 | 01:51 PM
Boomienutcake's Avatar
Hey guys,
Considering having put only about 70k on my '79 in six years (up to 184k now), I figure it's about time I change the filter and fluid out on it. A/T sucks, I know, have a manual that's been waiting to go in for a few years, just don't feel like braving it yet, or dealing with the lack of the clutch pedal mount on the cage under dash.
I'm just curious to know what anyone else uses in regards to the pan gasket. Cork, rubber? Should be cork on there right now. And if rubber, not sure if little more torque needed for a good seal.
Also, any opinions on metal screen filters vs paper/cloth filter. Having a hard time finding screen, maybe somebody can point me in the right direction.
Thanks!
Old Nov 9, 2012 | 02:29 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
Originally Posted by Boomienutcake
Hey guys, someone told me WanganDevilZ had a clutch pedal mount on the cage under dash.
Who told you that? I do have one actually, a spare from my Z that I had to send off to the undying lands, if it wasn't broken, I saved it in the garage.
Old Nov 9, 2012 | 02:34 PM
rogerz's Avatar
Grumpy & Helpful
if you can find a junker you can remove the whole cage clutch and brake pedal and all. have to kind of wiggle it and cuss but eventually it just sort of jumps out of there (after you remove the bolts of course). two clevis, 4 holding brake booster, 2 clutch master and three over to the left side I seem to remember. don't forget the hydraulic lines and clutch master slave
Old Nov 10, 2012 | 08:33 AM
PooFlinginMonke's Avatar
The 3n71b tranny pan gasket I bought is this one by ishino and sold by "thepartsbin".
It's not cork or rubber.
I had to pick a car and then search "pan gasket" to get it to come up.
Old Nov 10, 2012 | 09:26 AM
rogerz's Avatar
Grumpy & Helpful
rubber gasket in that service tend to squeeze out. that iswhy they use cork.
Old Nov 12, 2012 | 01:03 PM
Already have junker, actually still need to cut it up....bought it for $450, was converted to triple webers, sold them with the manifold for $500 off the bat, so got the car for a steal.
Have all the parts for the manual conversion, just not in the mood for it at the moment, heh...
Thanks for the info PooFlinginMonkey and rogerz. I've been a little leery of the rubber type, sounds sub-optimal to the sealing properties of cork.
If that gasket isn't either of the two, what is it??
FlyAssMelonBall
Jul 24, 2012 10:18 PM
Warpix
Jun 11, 2009 09:19 PM
efrain
Feb 25, 2006 06:46 PM
MacRocker
Jan 12, 2005 08:04 PM
GenHawk
May 27, 2003 07:21 PM
