Clutch
Old 07-02-2007, 06:16 AM
my79zx's Avatar
Clutch
Hay all, just bought a 78 Z and have an issue with my clutch. The slave is full of fluid but the pedal is dead. Straight to the floor, no resistance and will not rebound or engage. Can anyone help with some pointers. I am new to the Z world. Thanks.
my79zx is offline
Old 07-02-2007, 06:42 AM
I'm a Registered User!
SpeciallySpiked's Avatar
go look up where the pedals go under the dash (you might have to move some things) and make sure nothing has come undone
SpeciallySpiked is offline
Old 07-02-2007, 06:43 AM
Welcome to ZDriver & the "Z world"
Bleed the hydraulic clutch line & that should fix the prob.
NismoPick is offline
Old 07-02-2007, 08:42 AM
BC240Z's Avatar
Location: Kelowna B.C. Canada,.The Beautiful Okanagan Valley!.,.Canada's "Cali"
Whoah !
Ya... make sure you bleed the complete system well......as I understand it,..the "proportioning valve" will hold air, and is a bugger to bleed.
air in valve=no brakes... no good!
Good luck;
I just bought new flex-lines and wheel cylinders for the rear.. so I'm next.lol
(three brakes fer 4 yrs!!)
Todd/BC240Z
BC240Z is offline
Old 07-02-2007, 08:46 AM
BC240Z's Avatar
Red face
oops.... clutch......not brakes. hahahaha
well..same thing really..there is a small hydraulic "block" near the passenger side of the firewall. not sure of its intention in life, but it will fill with air..and the clutch will not engage.
One other thing. we just installed a clutch in my S30, and we forgot (DOH) to make sure the fork was locked into the "pivot ball" inside the bell-housing..again.no clutch action.
Todd/BC240Z
BC240Z is offline
Old 07-02-2007, 11:00 AM
Carl's Z's Avatar
Todd/BC240Z
That's what I was gunna suggest......Good one, BC
Carl's Z is offline
Old 07-02-2007, 02:53 PM
my79zx's Avatar
Ok so I am out at the car right now and the clutch pedal sucks in fluid and pushes it back out when I move it. I can see this with the resevoir cap off. I am not losing any fluid. will jack it up right now to se if I cant see something else wrong.
my79zx is offline
Old 07-02-2007, 03:02 PM
Bleed the system............................................ .................................................. ........................................
Old 07-02-2007, 09:50 PM
duckyz's Avatar
You can bleed it in two places, so be sure to do both.
One is up on the drivers side by the master brake cylinder, the other is underneath the car at the clutch linkage (slave cylinder). Make sure you do both. If you need help on how to do it, just ask. These guys and gals are really helpful and won't rag you.
duckyz is offline
Old 07-03-2007, 04:30 AM
my79zx's Avatar
My problem is the "One man bleed" procedure. That, and the fact that there is a 76 benz 450SL in the garage. I am going to buy rebuild kits for both. From what I read in my manual, its pretty simple. And cheap.........aside fro this problem and the small holes in the floor, the car is running and driving. I can't wait to drive my VW Corrado SLC replacement. Hopefully it will perform as well or better.
Any other common issues I should be looking for?
my79zx is offline
Old 07-03-2007, 05:42 AM
Try gravity bleeding the slave cylinder. Then do the clutch master. But I bet if you just do the slave. It will help out. All you do is turn out the bleeder screw where it barely drips. And let it come out, until it almost is coming out in a thin stream. Then carefully close it. If that don't work try it again. And whatever you do. Don't depress the clutch pedal, while doing this. Or you will have to start it over. I hope I explained it correctly. If not, somebody please chime in. I have problems sometimes, explaining certain things.
WildmaN is offline
Old 07-03-2007, 08:34 AM
The most effective way is with 2 people. Grab a neighbor, relative, or somebody walking down the street. Pump 3 times, hold, open bleeder valve, close, let up on pedal, start over.
If there is a lot of air in the lines, open bleeder & pump until a steady liquid stream comes out.
Old 07-03-2007, 09:20 AM
Doesn't post much...
RodMoyes's Avatar
Your car is NOT a '78' ... I't a '79'.
You need to ask a Mod to change your Screen Name now.
Rod.
RodMoyes is offline
Old 07-03-2007, 10:28 AM
my79zx's Avatar
A 79???? My title says 78, the plate on the drivers door says 8/78 and the Vin matches all the tags.......what's going on here...........
Will I regain the Return action in the pedal once it is bled? Right now I have to pull the pedal back. All springs and hardware are intact and not worn in the foot well/pedal cluster.
my79zx is offline
Old 07-03-2007, 10:34 AM
Just an FYI... car makers start the next years model in August of the previous year. Example... a 2008 model car will start being produced in August 2007. You have a 79 280zx. There were no "78 280zx's"
Old 07-04-2007, 05:02 PM
my79zx's Avatar
Right, so bleeding did nothing. So, for 50 bucks I went to the store and bought a new master and new slave cylinder. Problem solved. Both were toast from sitting for so long. My POS actually moves!
my79zx is offline
Old 07-04-2007, 05:44 PM
Super Siver & Black Stud
icice9's Avatar
congrats man.... now you can go drive it
icice9 is offline
Old 07-05-2007, 03:49 PM
highvolkage's Avatar
can someone tell me in detail how to bleed the clutch lines on a ZX? i'm helping a friend get one running and i got the motor running but the clutch is having the symptoms that was described in the first post and i want to try bleeding before i go any further
thanks in advance
highvolkage is offline
Old 07-05-2007, 04:04 PM
thanks in advance
Did ya miss this post on page one?
Old 07-05-2007, 05:45 PM
haha my bad but wheres the bleeder valve? on most cars i've worked on its between the slave and the clutch, same on these?
Old 07-05-2007, 06:24 PM
RodMoyes's Avatar
Buy a Hayne's manual... Please.
Rod.
RodMoyes is offline
Old 07-05-2007, 08:27 PM
Carl's Z's Avatar
Follow the fluid line down to the slave cylinder, and there's gonna be a valve on the slave cylinder itself. 8mm, I think......
Carl's Z is offline
Old 07-05-2007, 08:34 PM
^^^ indeed... it's pretty simple. Have you looked at the car yet? It's pretty freaking visible.
Old 07-06-2007, 05:44 AM
my79zx's Avatar
The bleeder screw is located on the Slave which is attached to the tranny. It is a little nipple just above the fluid line leading to the slave.
With the cap off the resevoir, open the bleed screw. Depress the pedal to the floor and then close the screw. Pull the pedal back up. Open the screw, press the pedal to the floor. Close the screw. Pull the pedal back up.
Repeat this process until the pedal retracks by itself.
Important......when pushing the pedal to the floor, watch to make sure the Slave piston is moving. If it doesn't, your Master is toast. The Master is located on the firewall next to the brake booster.
I had no piston action but my Slave was also siezed. The Slave cost $16.99 and the Master cost $29.88. I was able to purchase both at Advance Auto.
The process is really easy but will require 2 people.
Hope that helps!
my79zx is offline
LikeZcars
02-24-2013 06:41 PM
decalservice
08-26-2012 12:16 AM
JSimpson
FS: 300ZX (90-96)
07-25-2011 10:59 PM
z31_oldskol
10-09-2005 03:11 PM
jtmny1999
01-18-2004 09:04 PM
Quick Reply: Clutch
