cleaning has started
Old Apr 3, 2004 | 02:49 PM
Skully's Avatar
well i took off all the fuel lines, the valve cover and stuff. gonna take it to the machine shop n blast it all so i can paint it or whatever...
one Q do i need to take off the exhasst manifold to get the intake manifold off? i took of the 3 bolts on the intake off at the top...is there also 3 at the bottom? engine is in the car btw
Old Apr 6, 2004 | 03:11 PM
zr8d's Avatar
Absolutely right. I just took my intake off to remove the head for some machine work. Those bolts, depending on how old the car is, are very weak. I bust a head bolt and about 4 or 5 other bolts. A couple were on the intake. You may not be able to avoid this, but be careful nonetheless.
Old Apr 8, 2004 | 11:59 AM
I think three or maybe four of the underside intake manifold bolts have thick washers under them that hold both the intake and exhaust on.
You need to remove those, but that still leaves several exhaust manifold bolts in place so you do not need to remove the exhaust manifold. However, if you take off the intake you may not ever get the same quality of seal on the gasket. To replace the gasket obviously requries that both manifolds be removed.
Old Apr 8, 2004 | 04:15 PM
Skully's Avatar
crap ok....can you answer my Q about AFM and what to swap?
Magatetzz
Jun 2, 2013 03:30 PM
Tooquick260
Feb 26, 2013 04:56 AM
Lanoi
Apr 7, 2010 11:45 AM
RodMoyes
Nov 2, 2005 11:37 PM
assimilated420
May 4, 2005 07:51 PM
