Chts location
Old Oct 29, 2014 | 10:46 AM
DPDIDASA's Avatar
Chts location
Hello, I have 1980 non-turbo 280zx w/ a rebuilt engine. My car is running rich (black sooty spark plugs) I want to test my CHTS but it is not locate per FSM by the #5 spark plug or on the Thermostat housing. The Thermostat Housing has (3) sensor:
1) Thermotime switch (2 wire injector type plug conector)
2) Temperature switch -below Thermotime switch (Bullet type connection - single wire)
3) (not sure) Temperature sender - left of thermotime switch (single green wire approx. 2" long sticky out connects to bullet)
Could someone tell me what are my number 2 & 3 sensors are for & where might my CHTS will be located.
Thanks
Old Oct 29, 2014 | 12:52 PM
What cylinder head do you have? (It's not a P79 if there's no CHTS port).
Who rebuilt the engine and when did the problem start?
Looks to me that someone used either the wrong cylinder head or wrong thermostat housing. Do you have a disconnected plug somewhere???
There are 3 sensors...
#1: Water temp sensor for dash gauge
#2: Water temp switch for the aux fan
#3: Thermotime switch for the cold start valve.
Old Oct 30, 2014 | 03:35 AM
borini63's Avatar
N47 head no CHTS
Old Nov 1, 2014 | 11:09 AM
DPDIDASA's Avatar
Ok, Looks like I have a L28 engine block w/ a N47 cylinder head. Could the CHTS be located somewhere else?
Old Nov 3, 2014 | 09:15 PM
borini63's Avatar
You don't have one....
download the Factory Service Manual from
http://www.xenons130.com/reference.html
Old Nov 5, 2014 | 09:54 PM
DPDIDASA's Avatar
I've downloaded the FSM and it shows a CHTS. It appears I have a 79 block but a 1980 thermostat housing (See pics above). The thing is I cannot seem to find the wires for the CHTS.
Old Nov 6, 2014 | 06:36 AM
The CHTS wiring comes off of the EFI harness running at the firewall by the battery (loom that goes under the hood latch). If it's not there, then I'd assume whoever did the swap used the EFI for the head, and there should be a plug at the thermostat housing harness.
John300
Feb 17, 2013 04:02 PM
anniversary_Z
May 5, 2011 02:40 PM
mrbillishome
Mar 10, 2010 07:20 PM
drfrankenstein
Apr 30, 2007 08:49 PM
Carl's Z
Feb 26, 2007 08:43 PM
