car stalls:confused:
Old Jan 5, 2008 | 07:39 PM
scorpionp54's Avatar
after driveing my z for longer then ten minutes or so the stop in a store somewhere when i come back and start my car the engine feels like is goning to die and sometimes does. it only does this after being driven not cold start.
Old Jan 5, 2008 | 07:43 PM
Have you checked your timing, spark plugs / wires, AFM & CHTS connections?
Old Jan 5, 2008 | 07:54 PM
well i just replaced my distributor cap, rotor, plug wires,plugs,and i did an oil change but it started doing this before i did the tune upd
Old Jan 5, 2008 | 07:57 PM
A somewhat common cause of this "stalling when hot" problem is a bad ignitor (two prong unit on the side of the distrib for non-turbos).
Old Jan 5, 2008 | 07:59 PM
thanks i'll check it out tomrrow if its not raining,
Old Jan 6, 2008 | 08:23 PM
turboZ87.300's Avatar
Check the fuel pump, sometimes after the fuel pump warms you could (not common) have low fuel pressure. Look for vacuum leaks to. Clean the MAF / MAS with MAF cleaner...
Old Jan 6, 2008 | 08:26 PM
280zx's have AFM's not MAF's. I know what you meant, but there is a diff.
a280drvr
Mar 9, 2013 09:17 AM
bardabe
May 8, 2008 09:31 PM
project142
Oct 15, 2007 06:51 AM
jfairladyz
Jan 26, 2006 10:07 PM
Pistolio
Oct 1, 2003 03:56 AM
