cannot find this part anywhere!!!!! help!!
Old Apr 10, 2006 | 01:37 PM
gabrielzzz's Avatar
alright, this weekend i went over my week check up on my engine and i saw that all my coolant hoses had acid build up on the ends of them, so i was like, "ok, just have to do a coolant flush and replace it" and then i was looking at the heater housing, ontop of the throttle body and its leaking on all sides...cant find it anywhere, can anyone find one? and also, i think it might just be a bad gasket...does it use a gasket and do they sell the heater housing by itself or with the throttle body? any help would mean a lot.
Old Apr 10, 2006 | 01:42 PM
My advice... get a hose & bypass the throttle body all together. It's job is to keep the TB from freezing open / shut, or getting stuck (as air passes through a restriction, it makes the object cold). On a turbocharged engine, it's VERY unlikely to happen, as the charged air is warm already... no need to make it hotter.
So again... get a 90 degree bend coolant hose & bypass the tb.
Old Apr 10, 2006 | 02:01 PM
I bypassed that heater on my non-turbo in the arctic Seattle weather with no problems at all this last winter. I just used a straight line and curved it over the throttle body; didn't even need to buy a 90 deg bend.
Old Apr 10, 2006 | 06:04 PM
jfairladyz's Avatar
It's kind of along the lines of the injector fan: The OEM's would rather be safe than sorry. But do you really need these things? Of course not
Old Apr 10, 2006 | 08:02 PM
the first few summers i had with my z, i got vapor lock, so i threw the stock injector fan on and never happend again, you only really need it if you live in a desert though.
Old Apr 10, 2006 | 08:04 PM
when you think about it the 79-81 didnt have that hose at all, that means you dont need it and i live north of our cold buddy bleach, and mine didnt freeze.
Old Apr 11, 2006 | 08:24 AM
gabrielzzz's Avatar
wow....i guess you learn something new everyday...so it could only have positve effects by bypassing it than fixing it...is it recommended to plug up the holes in the housing? or not needed? it would look a lot more cleaner pluged up.
Old Apr 11, 2006 | 08:34 AM
Unbolt the housing from the throttle body. The throttle body itself is sealed. That will clean it up a little.
Old Apr 28, 2006 | 04:52 PM
gabrielzzz's Avatar
great! thanks for the tips guys, i just got some interior paint and some fresh new black carpet, i just did the drivers side last night and instead of just using a whole bunch of glue i used chrome screw to bolt it down, gives it a good billet aluminum look to it, slowly turning the interior from tan to black,and also as i took apart the dash, i found a dash speaker, made from MA audio, magnet is as big as the cone! hooking it up with the sound system today to see how it works, and then it will look pretty nice for the motorsport show this weekend, even though its not in the show, looks good tho.
Old Apr 29, 2006 | 10:50 AM
nismo619's Avatar
so bypass the coolent hose going to the throddle body ? i dont need it for my 280zxt as nismopick said.. right on !!!
jjdruffel
Jul 19, 2014 02:37 PM
gabrielzzz
Nov 22, 2005 02:27 PM
OutLAW Z
Sep 27, 2004 03:04 PM
300zx4me
Oct 28, 2002 04:25 PM
lil_racer_tony
Aug 15, 2002 09:14 AM
