Cams, Pistons, Injectors and everything else.
Old Dec 23, 2011 | 04:17 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
So I'm more than likely going to end up getting the Stage I Turbo Camshaft from MSA, I also probably figured that since my head/block is getting resurfaced/shaved, I might as well keep to dished pistons, and I found some ITM's in a .50 overbore.
I'm also grabbing the Supra injectors from my friends MKIII that he totaled the other week:
Evantually I will be getting a 240sx TB, doing the proper boring of intake for that, Z31T with Nistune
I've been doing searching, and found similar items, but never really in this combination. Just wondering what everyone else thinks, I hate to create another POS thread, just looking for input
Old Dec 23, 2011 | 04:51 PM
Supra injectors w/ Nistune are winners... I wouldn't waste money on an MSA turbo cam though. The stock L28ET cam is far from limiting.
Old Dec 23, 2011 | 05:00 PM
Among all the posts I skimmed through at work, you were looking for what people were looking at as far as power is concerned, I'm *wanting* about 250hp, possibly 300 someday
But I'll deal with the power gains later, I just want to get it running for now really
Old Dec 23, 2011 | 06:03 PM
I have no idea what you are talking about...
My setup is right at 250whp (~280hp flywheel) at 12psi boost...
-1mm overbore
-.5mm machined head
-T3/T4 hybrid turbo
-Z31T ecu
-60mm TB (matched intake)
-Stock turbo injectors
-Intercooler
and all the other goodies to keep it together.
Old Dec 23, 2011 | 09:00 PM
-1mm overbore
-.5mm machined head
-T3/T4 hybrid turbo
-Z31T ecu
-Intercooler
Maybe I should have asked this a long time ago, but what is your HP goal?
Sounds alot like what I've already got in mind, I've got a bore on the way, was looking at a bigger turbo and the Z31 with Nistune, TB, I can use the stock injectors, and keep the Supra injectors for a later date, and I've got an intercooler somewhere..
Old Dec 23, 2011 | 09:58 PM
-1mm overbore
-.5mm machined head
-T3/T4 hybrid turbo
-Z31T ecu
-Intercooler
That's alot work for a measly 250WHP.
Old Dec 24, 2011 | 12:39 AM
A 100hp increase over stock by doing some machine work, upgrading the ecu, and some other basic things, isn't "measly". Good try tho... ya made me laugh.
Old Dec 24, 2011 | 10:24 PM
It's because you aren't promoting the vastly superior VG30E or VG30ET....
Old Dec 24, 2011 | 10:47 PM
Not to rehash the past, but we've discussed the "L28ET vs VG30ET" before:
https://www.zdriver.com/forums/280zx-performance-technical-79/l-motor-build-questions-30274/
The VG30 is only about 8 years newer than the L28.... the VG30 is now 27+ years old.... Yes, it's modern compared to the Ford Model T engine.... but there have been plenty more modern engines / engineering since the early 80's.
I don't get why people keep talking about the VG30ET over the L28ET... it's a pointless swap into an S30 / S130 unless you are doing it just to say you did it.
Blah blah blah... I won't argue a brick wall.
Old Dec 24, 2011 | 11:04 PM
Lol - I was just giving Hoov100 the gears before he went off on his VG tyrate...
Old Dec 31, 2011 | 02:52 PM
Having a larger bore requires a head gasket to match the new size of the cylinders, MSA doesn't sell overbore headgaskets, neither does the Surfside japanese place we have here in town
Where get 1 OB HGs?
Old Dec 31, 2011 | 03:17 PM
The MSA MLS head gaskets are sized for over bore.
Old Jan 1, 2012 | 07:04 AM
My New Year's resolution:
Is to get this running by March.
With your knowledge and experience, and my hands and tools, we can do it.
Old Jan 1, 2012 | 03:09 PM
Where get 1 OB HGs?
I didn't have time to post this yesterday:
http://www.thezstore.com/page/TZS/PROD/10-2454
http://www.thezstore.com/page/TZS/PROD/PEM09/10-2455
Originally Posted by MSA
Thickness is 1.0mm, with a 90.5mm bore.
And I mod'd mine (drilled extra holes) due to this:
Gasket is for non-turbo applications only, and NOT for use with L-6 Turbo Heads (P90, P90A) as some oil passages would be blocked.
Old Jan 1, 2012 | 04:09 PM
Go with the "A" grind NA cam - it's good to about 400HP on a turbo...
I'd double check but I wouldn't be surprised if the stock head gasket will work with a .5mm overbore....
Old Jan 9, 2012 | 05:34 PM
So basically I'll be fine if I lay my turbo HG on top, stencil the correct holes, and drill?
Don't exactly see what you're on about, wouldn't the turbo cam be a better application?
Old Jan 9, 2012 | 09:42 PM
Dude time to research the "A" grind from the NA (P79, etc). It's the hot ticket cam for a stock to moderate modified turbo car.
Olden day turbo cam theory was lots of overlap because turbos were not very efficient back in the day. Add an intercooler and you effectively increase efficiency (sorta in a thermal emulation kinda weird way). Regardless bringing the charge temperature down lets you run a more agressive cam without detonation - ala "A" grind.
Old Jan 10, 2012 | 02:46 PM
I had intended on getting an intercooler, I had also planned on doing water/meth once I got a bigger turbo, but thats about a year and a half down the road.
Old Jan 10, 2012 | 03:36 PM
If your getting a cam, you might as well get a custom grind if you plan on going MS or nistune.
No need for water/meth unless you plan on running lean and on the gnats *** of detonation. I think the main focus of any turbo build should be on airflow, Like porting the **** out of the head and manifolds and strait intake/exhaust pipe routing.
Old Jan 10, 2012 | 07:39 PM
New .20 over pistons on the way.
Now, How do I remove the wrist pins from the old piston/rods so I can reuse the rods?
Old Jan 10, 2012 | 08:45 PM
Hopefully you don't plan on doing this w/o the FSM...
FSM section EM-16: PISTON PIN IS PRESSED INTO CONNECTING ROD (0.6 - 1.7 US ton).
Old Jan 11, 2012 | 08:34 AM
I think I'll go with the opinion of some of the top L series engine builders in the country on their opinion on the "A" grind cam. But of course to each their own....
Old Jan 22, 2012 | 09:23 PM
Will I be able to reuse the wrist pin? Or do I need to get new ones, if so, where?
Old Jan 23, 2012 | 08:58 AM
If you press them out correctly, you can reuse them. Need new ones? Nissan or your local machine shop.
Old Apr 2, 2012 | 04:13 PM
Alright, been on a little hiatus for a while, but I've run into a problem, I have multiple Con-Rods, but none of the numbers match, and some of them have a very small lip on the groove, which means they'll be off on the crank.
However, I do have somewhat of a set, I have six, but I don't have 1-6, I have like, two number 3 rods, or something like that (In the sense that the numbers match on the stamp)
Actually, I just went out into the garage, and they all have somewhat of a small lip on them that I can catch my finger on, some are worse than the others, but I probably have about two that are perfectly fine.
Thoughts? Ideas? The machine shop said they could bore them out, but that the engine would be out of balance etc. etc.
