Camber?
Old 03-21-2009, 01:25 PM
  #26
Pr0n Addict
KasbeKZ's Avatar
Indeed neg camber is when the tops of the tires point inward.
doesn't this make it look like neg. camber is the tops of the wheels pointing outward?
https://www.zdriver.com/forums/300zx-z31-brakes-wheels-suspension-chassis-76/rear-camber-perfection-27414/
KasbeKZ is offline
Old 03-21-2009, 01:35 PM
  #27
camber is the top point inward at the body making /-----\ shape when its negative and you were looking at it from head on at the cars face or ***. and vice versus this is positive camber \-----/ though exaggerated, you should get it.
snwbrderphat540 is offline
  #28
Anally Challenged
mike88se's Avatar
This is negative camber:
mike88se is offline
Old 03-21-2009, 01:55 PM
  #29
Pr0n Addict
KasbeKZ's Avatar
yeah. ok. i just thought it was the other way around.
KasbeKZ is offline
Old 03-21-2009, 02:20 PM
  #30
Haterade by da gallon!
280zx2by2's Avatar
it wont say if its adjustable though....
boy are you stupid or something? thats not the argument, the argument is that there is rear camber on these cars from factory...
and anyway it will tell you that it is non adjustable or adjustable, all you have is the print off that is given to customers...
280zx2by2 is offline
Old 03-21-2009, 06:36 PM
  #31
Get outta my way.
DatsunKid's Avatar
Lol my dream z would be an rb30 240z with triple mikunis!
DatsunKid is offline
Old 03-21-2009, 06:46 PM
  #32
Intrawebz Wizard
BlueKitsune's Avatar
My dream Z would be the Devil Z! Or at the lest a 240Z that looks nice ^^"
BlueKitsune is offline
Old 03-21-2009, 06:59 PM
  #33
280zx2by2's Avatar
never seen a carbed rb before, have seen an rb with carbs converted to blow through TB's like you see on 4age motors... sounded like heaven
ps. if this thread wasn't off topic before it is now
Old 03-21-2009, 07:06 PM
  #34
Intrawebz Wizard
Its ok if its Off Topic, I got my answer anyways lol
Darn it! I for a 240Z for sale finally and it has a V8 swap but Of course Theres no way in hell I can get $3k ... If I could buy it I would sell the engine and transmission from it as I have an L28E thats looking for a home in a 240Z
.......I do think I can get a loan for a car that old for that much with the economy atm
Old 03-21-2009, 07:07 PM
  #35
Get outta my way.
DatsunKid's Avatar
Back to subject then, yes your car will have slight negative camber but it shouldn't be noticeable.
Old 03-21-2009, 07:22 PM
  #36
280zx2by2's Avatar
and if it is noticeable or you have accelerated tire wear on the inside of your tires go get the car checked by a reputable service station...
Old 03-21-2009, 09:54 PM
  #37
Intrawebz Wizard
The wear is fine oddly It just looks off So Im not that worried now.
Old 03-21-2009, 10:11 PM
  #38
Intrawebz Wizard
OT Again cuz I dont wanna make a new thread.
You know the bar that hooks to the idler and pitman arms? And the tierods hook to it? How do you replace that balljoint that hooks to the pitman arm? Or do I replace the entire thing?
Old 03-22-2009, 06:11 PM
  #39
sho_shane's Avatar
Um why are my post gone>
sho_shane is offline
Old 03-23-2009, 09:29 AM
  #40
Intrawebz Wizard
Idk.
Still trying to figure out what that part is call and where I can get it.
Old 03-23-2009, 11:01 AM
  #41
https://www.zdriver.com/forums/lounge-off-topic-219/bitch-slapping-cont-merge-camber-thread-28161/
Idk.
http://nissan4u.com/parts/280zx/us_s...llustration_5/
1 Bolt 2 0,06 kg / 0,132 lb
0111500021
IDLER FIX
'78, July — '81, August
2 Linkage steering 1
48500P7125
alternate: 48500P7100
'78, July —
48500P7100
3 Bracket idler arm 1 0,41 kg / 0,905 lb
48531P7100
48531U8701
'78, July —
4 Washer-plain 2 0,014 kg / 0,031 lb
48365Y0100
alternate: 48365Y0101
5 Nut-hex 0,007 kg / 0,015 lb
0891244010
6 Bush-idler arm 2 0,007 kg / 0,015 lb
48544H1000
7 Pin-cotter spli 0,01 kg / 0,022 lb
0892132510
8 Plug-filler 1 0,002 kg / 0,004 lb
4018973000
9 Idler steering 1 0,9 kg / 1,987 lb
48530P7100
48530U8701
'78, July —
10 Bolt-hex 0,016 kg / 0,035 lb
0812083510
11 Nut 6 0,015 kg / 0,033 lb
0122700032
alternate: 0122700081
0122700061
'78, July —
'78, July —
'78, July —
12 Nut-hex 0,004 kg / 0,009 lb
0891110810
13 Bar-cross rod 2 0,15 kg / 0,331 lb
4851228501
14 Arm-pitman 1 0,58 kg / 1,28 lb
48502S0103
15 Washer 1 0,04 kg / 0,088 lb
4853413200
48541H1000
16 Clamp 4 0,07 kg / 0,155 lb
4856228500
17 Nut 0,016 kg / 0,035 lb
0891244210
18 Washer-spring 0,021 kg / 0,046 lb
0891515010
19 Plug-filler 1 0,002 kg / 0,004 lb
4018973000
20 Cover-dust 1 0,003 kg / 0,007 lb
4858721001
21 Nut-hex 0,04 kg / 0,088 lb
0891125010
22 Washer-spring 0,001 kg / 0,002 lb
0891513810
23 Rod cross 1 2 kg / 4,415 lb
48560P7125
24 Cover-dust 1 0,016 kg / 0,035 lb
48522S0101
25 Socket side rod, outer right-hand 2 0,41 kg / 0,905 lb
48520P6525
26 Socket side rod, inner 2 0,74 kg / 1,634 lb
48521Q0125
27 Cover-dust 4 0,016 kg / 0,035 lb
48522S0101
NismoPick is offline
Old 03-23-2009, 12:40 PM
  #42
280zx2by2's Avatar
thrust angle, thats that one that no one cares about...
Old 03-23-2009, 04:03 PM
  #43
If I'm reading this correctly, and I like to think that I am (Ocean's Eleven quote), the rear camber range is from -0.1 to +1.4 ... hum... that would mean more of the range would be in the positive? What!?!?! -0.1 isn't much of a negative camber....
What did I say at the beginning? Oh yeah...
The 280zx usually doesn't have any negative rear camber on a stock setup. If any, it's a bit of positive camber.
Old 03-23-2009, 04:40 PM
  #44
280zx2by2's Avatar
well your not reading it correctly, the negative carries over (any -0.1 to -1.4 degrees of camber) positive camber makes it easier for the steering wheels to turn the car, so unless datsun started selling a 280zx with rear wheel steering systems... idk mabe they did lol
you know it makes sence quit being difficult
Old 03-23-2009, 06:22 PM
  #45
the - doesnt carry over, all my print outs put the - again im looking at one right now.....
Old 03-23-2009, 06:38 PM
  #46
280zx2by2's Avatar
thanks for the extra evedence
Old 03-23-2009, 07:04 PM
  #47
There is no carry over. It is what it says. Without a negative symbol next to it, it is positive.
Bleach is offline
Old 03-23-2009, 07:11 PM
  #48
so does this mean you admit stupidity?
Old 03-23-2009, 08:32 PM
  #49
Intrawebz Wizard
Thanks for the part info nismo, I take it the joints on the end of that arnt replaceable huh? ugh...$400 part...
Old 03-24-2009, 06:47 AM
  #50
Which joints are you talking about? The "side rods" (#25 / #25) right?
Quick Reply: Camber?
