Camber?
Should the back tires on your Z cars have a noticeable negative camber? Or is that a bad thing?
Yes I know my shocks are bad but I think the front is much worse then the back so Im just curios lol |
The 280zx usually doesn't have any negative rear camber on a stock setup. If any, it's a bit of positive camber.
Er... So ya that means my back shocks are more then likely going out too huh? Next paycheck can not come any sooner lol
Negative is facing inward right? to the car? I like the way the car handles like that but it cant be good on the tires |
Not shocks... the springs. Shocks dampen the bumps, the springs control the rebound, and ride height.
Indeed neg camber is when the tops of the tires point inward. |
(Post 253847)
280zx's, at least mine (as proven by a hunter hawkeye running winalign software) has several degrees of non adjustable negative camber on the rear wheels stock... something weird just happened... :paranoid: |
(Post 253859)
Nismo wrong!!!! :103:
280zx's, at least mine (as proven by a hunter hawkeye running winalign software) has several degrees of non adjustable negative camber on the rear wheels stock... something weird just happened... :paranoid: And a little negative camber is a good thing as someone here mentioned I think. |
(Post 253859)
280zx's, at least minehas several degrees of non adjustable negative camber on the rear wheels stock... My 280ZX is seemingly stock but it rides really high in back. I'm not the original owner so I can't say what kind of springs are in the car anyway. Plus, some springs sag over time and you end up with some negative camber. |
... what is the stock ride height? I dont even know
My bet is that your springs are just wore out.
Originally Posted by Bleach
(Post 253866)
How do you even know yours is at stock ride height?
Originally Posted by mike88se
(Post 253862)
(Post 253870)
Ah ok, and thats from ground to frame I take it? and yes I have the stock 30 year old suspension! So Ya lol Thank you!
(Post 253859)
warning, blue! don't believe anything 2by2 says unless someone reputable on here agrees/backs him up.
lol I have no clue what to say to that.
But I remember hearing elsewhere that Z do have a slight negative camber on the back for handling so he may be right But mine its really noticeable |
almost any RWD car has slight negative camber, but i mean SLIGHT
Even a solid axle car!? Yes Im kidding lol but ya this isnt slight this is "What the hell with with your tires?" bad
(Post 253875)
it is NON ADJUSTABLE
Glad I asked you first though... :023: |
(Post 253909)
(Post 253920)
So even if I adjust the inner pivot points on the control arms by welding or slotting it wont' change anything? :017:
(Post 253893)
Prove me wrong buddy boy.
(Post 253943)
Waiting for you 2by2....
what does that prove? a print off of your car's alignment numbers?
(Post 253947)
epic fail of your noobness snw:012: |
yeah, so.... it wont say if its adjustable though.... i got alignment sheets in my room, i know what on them. i wanna punch those stupid glasses right into your face right now!
seriously though... those glasses are terrible, they are much to small for your face, make you look like a hippy or something. |
