Bored/Stroked
Old Jun 14, 2007 | 10:17 PM
wgc_3's Avatar
Bored/Stroked
Question!
If I was to bore, and stroke my engine would I have to modify the FI?
Thanks,
wgc_3
Old Jun 14, 2007 | 10:21 PM
Nope... but if you want to get the most "bang for your buck" you should.
Old Jun 14, 2007 | 10:22 PM
wgc_3's Avatar
What would I need to do to it?
Old Jun 14, 2007 | 10:26 PM
Depends on you...
Simple things: larger fuel pump & adjustable fuel pressure regulator will usually do the trick, but to get the most out of a bored AND stroked, you should prolly invest in an aftermarket fuel management like MSnS or SDS.
When you say "bored & stroked" I assume you are talking about a 3.0 or 3.1L stroker?
Old Jun 14, 2007 | 10:29 PM
wgc_3's Avatar
Ok thank you.
Old Jun 14, 2007 | 11:35 PM
could just get a lil larger injectors though, but if your STROKING it (hehehe) thats alot of freaking money, you need the maxima ld crank and 240z rods and then stroker pistons no? or did i mix up different methods to make a stroker? either way it seems like to much non neccessary work to me...
Old Jun 15, 2007 | 01:06 AM
jfairladyz's Avatar
u pretty much hit it on the head. I do believe though its the KA pistons u can use for the stroker if u wanna source all junkyard parts to save a few bucks. But yeah a lot of money for little gain. You'd probably put less into getting the head worked and going with MS and get more power than just stroking it. But then if you go stroker you may as well do those things anyways if you wanna see any gains out of it. Of course you can go with ALL of the above if your pockets allow it hell...why not throw a turbo on there and get the best of it all!!! 3.1T running on MS and no money left to pay for the gas so you can start the thing
Zdon
Dec 25, 2014 11:09 AM
BlueKitsune
Sep 6, 2010 10:05 PM
BlueKitsune
Apr 12, 2009 10:34 PM
skittle
Jan 3, 2007 04:57 AM
s/cL3.0
Nov 14, 2005 07:54 PM
