Bore/Stroke
Old Jan 8, 2004 | 09:39 AM
The boring is much easier to accomplish. The whole task of installing a stroker crank is much more expensive. I believe you can achieve pretty close to a 3.0 just by boring.
2.95 or so which rounded up could be called a three liter. The little bit of displacement isn't going to add lots of power. Its how you build the engine in other ways... but the added air capacity will help.
The problem is that the typical KA24DE flat top pistons that can be used are shorter and will have a negative deck height which lowers compression. With a stroked crank they have a slightly positive deck height and need a tall head gasket. Its very complicated either way.
Stukinit
Jul 9, 2013 09:04 PM
ellisdaddy917
May 1, 2009 08:04 PM
scorpionp54
Aug 27, 2008 11:35 PM
gen_d_tune
32
Dec 6, 2006 07:20 PM
Heavy_Z
Mar 13, 2002 06:18 AM
