BOLTS BOLTS and yes more bolts
Old May 14, 2008 | 01:26 PM
zstudent's Avatar
Unhappy BOLTS BOLTS and yes more bolts
Ok so I just got home from my semester internship only to find that my mom did a clean sweep in the garage and tossed almost all of my bolts and parts that I needed for my 280zx, and I was looking to you all for some help. I was able to track down the motor mount bolt at a dealership but as far as the transmission mounts I am at a loss, anybody in the SoCal area that knows of a good place or can at least tell me the sizes of those bolts would be most appreciated. thanks
Old May 14, 2008 | 01:42 PM
https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/quick-question-25612/
and go to NAPA.
Old May 14, 2008 | 08:12 PM
zstudent's Avatar
ok so are those the bolts for the transmission mount?
Old May 25, 2008 | 08:16 PM
zstudent's Avatar
ok another bolt question, I got the motor and tranny in that was a lot simpler than i though, anyways I need to know the bolt size for the clutch operating cylinder the two that attach it to the clutch housing, and i need to know the four that go through the companion flange on the drive shaft.
Old May 25, 2008 | 08:20 PM
Clutch operating cylinder??? Clutch housing??? Do you mean the clutch slave cylinder and the transmission bell housing???
Old May 25, 2008 | 08:41 PM
zstudent's Avatar
i am just going by what the hanse manual calls them i am no expert at the inner workings of z's this is the fisrt car i have ever work on my skil before this was oil changes and intakes thats about it so any help would be much appreciated
Old May 25, 2008 | 08:51 PM
Yeah that's the clutch slave cylinder. All those bolts should be 12mm heads...
Old May 25, 2008 | 09:25 PM
zstudent's Avatar
the driveshaft was 12mm but the clutch slave isnt
Old May 25, 2008 | 10:01 PM
lww's Avatar
lww
Head Muckraker
Are you trying to replace the bolts or find a wrench that will fit them? I don't think the head size is going to matter if you're trying to replace them, you need the thread size and pitch which is M6x100 if I'm not mistaken. That's 6mm x 1.00 threads per MM, but I could be wrong, I don't have my manual in front of me...
E_Rock
Dec 16, 2014 04:57 PM
Blue_streak
Jul 9, 2008 08:02 AM
snwbrderphat540
Nov 28, 2006 09:27 AM
CatchinZs
Sep 26, 2003 05:03 PM
Drax240z
Apr 1, 2001 06:48 PM
