Bmw fuel injectors in a 280zx?
Old Jul 29, 2017 | 01:42 PM
Austin26860's Avatar
i have been trying to get a 280zx to run and I'm curious if I can use injectors from a late 90s 2.8l bmw. I believe that the injectors spray about 200cc. Will it work and if it does is there anything I would need to do for them. The injectors have tips on them that I would have to take off for them to fit also.
Old Jul 31, 2017 | 01:08 PM
Long answer short, yes they will work.
Longer answer: They are 14mm o-ring high impedance injectors, requiring an aftermarket o-ring rail (Pallnet rail). IIRC the BMW injectors have splines on the pintle caps? Technically you can grind them off with a Dremel and then they will fit into the intake ports. I am using high impedance 14mm o-ring 308cc GM fuel injectors on my 280ZX Turbo.
If you can't get the pintle caps to fit, then you can remove them and use the stock style. Pallnet also sells pintle caps... pallnet@hotmail.com
Old Jul 31, 2017 | 03:50 PM
So far I used the bmw on the stock fuel rail and they fit in by removing the pintle caps. The only problem now is that when i pulled the fuel rail out they are not spraying anything out. Im guessing this is where I need a Pallnet rail?
Old Oct 16, 2017 | 01:22 PM
JAyD_917's Avatar
Did you ever get them to work with the stock rail. I'm working on mine now(it was running bad and one finally started visibly leaking) and I'm exploring my options
tube80z
Jul 8, 2005 09:51 AM
duckyz
Dec 22, 2003 09:38 AM
duckyz
Aug 29, 2003 03:02 PM
Spudz
Jun 5, 2003 09:28 PM
z432
Dec 29, 2001 10:08 AM
