Annoying problem
Old Apr 4, 2008 | 10:09 PM
JBs280Z's Avatar
Annoying problem
I have an hour drive to work and back most of which is interstate. When I'm leaving home or leaving work, my 1980 280zx 2+2 runs perfectly fine the entire stretch of interstate but when I get off of the interstate, after approximately 45 miles worth of driving and only when its warm outside, my car begins to spit and sputter as I come to a stop and most times will die after which it is very difficult to restart and keep running. The car never over heats but the engine temperature is always higher than normal. If it is cool or cold outside I never have a problem. PLEASE HELP ! ? I just cant imagine whats causing this problem.
Thanks.
Old Apr 4, 2008 | 11:00 PM
Have you checked the timing? Spark plugs? Cap & rotor? Wires? Sensors & connections?
Old Apr 4, 2008 | 11:27 PM
JPerkins's Avatar
the dying after an interstate run and only when you try to stop sounds like what happened to my 280zxt. the egr valve was malfunctioning somehow. disconnected the vacume and capped it off with a rubber cap and never had another problem with it dying after it got warm.
Old Apr 5, 2008 | 09:40 PM
JBs280Z's Avatar
The egr valve did cross my mind so it's good to hear that it caused a similar problem for you. I'm going to give that a try, thanks for the input.
Old Apr 5, 2008 | 09:42 PM
JBs280Z's Avatar
Most of them yes and while a good thorough tune up I'm sure would do some good, I don't think any of those things are bad enough to cause my problem. I may go ahead and freshen the old girl up though just for good measure. Thanks for the reply.
Old Apr 6, 2008 | 12:32 AM
lww's Avatar
lww
Head Muckraker
The next issue to check AFTER you've verified all the basics are in order is the Ignition Module on the distributor. If it's going/gone bad, they have a tendency to act up when they overheat. Because they are so freakin' expensive, it should be one of the LAST things you try.
Old Apr 7, 2008 | 06:41 PM
JBs280Z's Avatar
Ok
Hey thanks, if I don't get it straightened out I'll check that.
Old Feb 18, 2011 | 05:10 PM
workingprogress's Avatar
its the coolant temp sensor trust me its only 35 bucks or so get it and repalce it, i would also clean the connectors and sensors
-Xavier
Uber old thread... please check the dates.
carfanatic
Feb 16, 2010 10:09 PM
280zx2by2
Polls
63
Oct 17, 2009 07:37 AM
JBs280Z
May 29, 2007 10:51 PM
Skully
Apr 25, 2006 06:56 PM
zpeedracer25
Jun 22, 2003 08:36 PM
