about to clean the bay...
Old Apr 19, 2006 | 09:13 PM
chinesekid's Avatar
hey... quick question.. im about to pressure wash my engin bay.... what do i have to do before i clean it?? like on the sensor and stuff.. theres the rubber thing covering the wires, there crack and i can see the wires on some of them... what should i do? and will anyhting happen if i wash it like this?
Old Apr 19, 2006 | 09:17 PM
https://www.zdriver.com/forums/280zx-s130-forums-77/wierd-engine-problem-17948/
don't spray the distrib, tps, or afm.
Old Apr 19, 2006 | 09:29 PM
nismo619's Avatar
u know what i do ? i buy a can of engine degressor and use a tooth brush of all things and with the engine off and cool i spreay it on the intake manafold all around and i scrub off all the grim and stuff then i do the same to the side of the egnien block were the spark plugs are... i cant stand my engine a little bit dirty .....
Old Apr 19, 2006 | 09:48 PM
jfairladyz's Avatar
Pick up a can of compressed air and when you're done spraying it all down use the compressed air to spray inside all the connectors to get them dried out.
Old Apr 21, 2006 | 02:44 AM
skittle's Avatar
Taste My Rainbow
if you have a lot of grease use something called "gunk" it will clean it up real good. just make sure you cover up all the electronic stuff... I did that all i did was disconnect all the electronics and labeled them bundled it up, wrapped it in saran wrap and covered the dizzy with a plastic bag. then sprayed the gunk on it let it soak for about 10 mins or so then power washed it off... the bay is sooo cleacn you can literally eat off of it...
Old Apr 21, 2006 | 02:50 AM
skittle's Avatar
Taste My Rainbow
oh yeah and to clean out your engine and fuel system get a can of "Sea Foam" and put it in your gas tank and in your engine where you add the oil. let it run for about 10-15 mins at idle and that will clean out the"gunk" inside your engine as well. not to worry you might see blue exhaust come out but thats ok its just the sea foam..
Old Apr 21, 2006 | 03:26 AM
japanz's Avatar
I say...
Simple Green
Old Apr 21, 2006 | 06:59 AM
Purty S130's Avatar
I used that gunk stuff numerous times. Works really well.
Old Apr 21, 2006 | 07:22 AM
jfairladyz's Avatar
Murietic acid does a really good job too
Old Apr 21, 2006 | 10:14 AM
280zx81's Avatar
I'd have to say simple green and a steam cleaner always works best for me
Old Apr 21, 2006 | 11:48 AM
skittle's Avatar
Taste My Rainbow
yeah the acid is always good as long as you don't let it stay on the rubber hoses and what not... we don't need any melted rubber all over the bay... if you decide to use the acid dilute it well. and remember kids stay off of the acid... lol
Old Apr 21, 2006 | 08:05 PM
jfairladyz's Avatar
It works really good when you need to etch a layer off your driveway. I dont know that I'd actually put in my engine bay with the engine still in there though
Old Apr 22, 2006 | 10:15 AM
skittle's Avatar
Taste My Rainbow
yeah no joke all it is is a very diluted form of hydroclouric acid i think...
mcoman
FS: 300ZX (84-89)
May 14, 2014 06:46 AM
ecb12
Feb 19, 2012 04:23 PM
280gty
Feb 23, 2008 12:17 AM
SoCal-s130
Sep 24, 2006 09:07 PM
Spot
Jun 24, 2002 05:52 AM
