83 280zx fuel filter(S)?
Old 06-23-2013, 11:29 AM
sparkycon's Avatar
My 83 280zx sat for a long time. I got her running and with lots of help from the great folks in third forum, running well. It started hesitating REALLY bad a couple of months ago, now it will not start at all. Well, it will start for about a second and then it cuts off. I read where this could be the fuel filter, so even though I replaced it a couple of years ago, I replaced it again. It did drain some brown looking crap out of the bottom of it, but still won't stay started. I replaced the igniter a year or so ago, and put new plugs and wires on it. Is there a second fuel filter somewhere? If so, where is it? Could it be one of the fuel pump relays? I have no mechanical ability whatsoever, but I love this car and want to drive it again...
sparkycon is offline
Old 06-23-2013, 12:51 PM
Grumpy & Helpful
rogerz's Avatar
you need to put a pressure gage on the fuel ring to find out what is wrong. if it starts then pretty much you know it is a fuel delivery problem. a gage will give you information that you need.
rogerz is offline
Old 06-23-2013, 06:05 PM
Genewiz's Avatar
Yes there is a fine mesh filter attached to the pick up line in the fuel gauge assembly that sits in the tank. This can get caked up or the line gunked up or rusted up also. Assembly is accessible from the trunk area under the carpet. The FSM will give instructions on its removal. You can spray out the removed assembly with Carb cleaner. Adding an inline fuel pressure gauge would help to determine if you need to go that route.
Genewiz is offline
Pez
08-29-2014 02:00 PM
Carl's Z
01-26-2007 09:24 PM
c-murder
16
04-10-2006 05:46 PM
Brewster
01-19-2004 07:07 PM
EatmyDust
12-05-2003 08:46 AM
Quick Reply: 83 280zx fuel filter(S)?
