82 280ZX thermostat bleed hole?
Old Mar 8, 2011 | 04:15 PM
ZCHondaCRX91's Avatar
Hey, I got a 82 280ZX that I'm fixing up. I had to replace the exhaust manifold and took off the whole intake and everything off. I was putting the thermostat back in and I noticed that the bleed hole said to face to the left of the engine (toward the passenger or driver's side)? Also, is there a gasket that should go on it, when I took it out it had no gasket on it. If someone has a nice picture I would appreciate it. Thanks.
Old Mar 8, 2011 | 04:34 PM
Welcome to Zdriver man. As for the thermostat, as long as you put the spring to the bottom, you should be fine. I have the same exact year of 280zx you have. So did you also remove the thermostat housing to head? If so, you need to get a gasket for that also. You can also make your own gaskets out of gasket maker. I have done it before. Good luck.
Old Mar 8, 2011 | 06:46 PM
Yeah, took the whole thermostat housing off, so I put some gasketmaker on it. Is there suppose to be a gasket on the thermostat? Thanks for the quick response.
Old Mar 8, 2011 | 07:36 PM
Okay that's good. Yes there should be a gasket that goes around the thermostat. It should be a dollar or so at the most. Otherwise like I mentioned, you could make a gasket out of sheets of material. And you are welcome.
InfiniteRPM
Jan 29, 2015 04:23 PM
dobber
Apr 4, 2014 03:17 PM
Z_lover
Jun 6, 2013 01:32 AM
ddatsun
Nov 12, 2007 12:44 PM
dhizzy
Aug 19, 2002 09:05 PM
