79 280zx Heat Problem
Old Dec 27, 2003 | 11:42 AM
Skully's Avatar
ok mine is 81 has vaccum system so i assume its same probably that the vaccum hoses are disconected under there , my AC same think i looked under and it was disconected so i gotta hook it up...check the hoses for leaks and check if they are all connected all the way to the engine
Old Dec 29, 2003 | 08:45 PM
duckyz's Avatar
I don't know how the electrical is in your model year, but I have a tube fuse under the dash ('83 n/a) that is connected to the fan motor. The only way I can access it is to crawl under the dash with my head on the floor and feet either up on the back of the seat, or twisted off on the ground...wichever is more comfy! Pull it out and give it a look............solved my heat problem.
Now to find someone to charge my a/c...........
Old Jan 2, 2004 | 05:44 PM
LaGSaLoT's Avatar
Heavy D
heat
I too have a 79 280zx with heat problems, I am currently in the process of tearing out everything through the dash, sofar its been a biotch trying to get at all the nuts and bolts. If you find out how to fix it tell me, and ill do the same. By your explanation, we have the same problem.
Old Jan 3, 2004 | 08:07 PM
LaGSaLoT's Avatar
Heavy D
Well I tore it up today. You have to take off EVERYTHING to get to the fan. I use the original datsun manual, it makes it seem like these parts just slide in and out with a flick of the wrist. After 50 cuts on each one of my fingers because of sharp metal objects, i gave up. I got to see the fan, its right behind the faceplate and a little to the left. I didnt accomplish anything either, if I had a garage i would gladly take apart the whole dash but I dont, so if you find out the easy way, tell me! Till then i guess ill ride around in a jacket and carry an extra one if i wanna go on a date or somethin. Good luck tearing it up, you'll need it.
82-280ZX
May 2, 2015 09:53 AM
ol55
Dec 17, 2013 02:36 PM
Aim2Gain
Aug 13, 2011 10:31 AM
fozs00
Nov 28, 2006 01:07 PM
nuzxowner
Feb 13, 2005 06:38 AM
