Heat/AC HELP!!!!!!!!
Old May 15, 2005 | 09:16 AM
fozs00's Avatar
I have a 96 300zx 2+2 and things are not looking good. Here's my problem yesterday my heat/AC went out. I cranked up my car to go for a spin everything was going fine to my AC quit blowing so I tried the heat also nothing happen. I have auto controls of course. I checked the 7.5AC fuze in fuze box it was good. As far as my auto controls everything still seem to be working. All the vents seemed to be working, I used the AC controls to open/close them. But still no AC or Heat nothing blowing at all HELP!!!!!!!!!!!!!!!!
Old May 23, 2005 | 05:14 PM
fozs00's Avatar
Fixed Problem!!!!!
He's the answer to the question nobody wanted to comment on. Replaced the blower and that fixed the problem. Power was going in but wasn't going out. Hope this helps somebody.
Old May 23, 2005 | 06:11 PM
CanyonCarver's Avatar
Jack Of All Trades
I definitely appreciate the feedback. It's good to see that you solved the prob. Did you pull the motor and then try putting 12v power to it to see if it worked by itself?
Old Nov 27, 2006 | 03:06 PM
Dave Hamby's Avatar
Can someone tell me if the Blower motor is easily replaced. Mine went out (I believe) yesterday and by the way, it's 36 degrees out right now and snowing. Would like to get it fixed right away. I've searched the forums for threads on Heater, Blower, Fan, etc. but this is the only one I could find with any comments about replacing the blower motor.
Help,
Old Nov 27, 2006 | 03:08 PM
Help,
Wow... diggin up old threads! Have you checked the fuses?
Old Nov 27, 2006 | 03:14 PM
Dave Hamby's Avatar
I have only checked under the hood whilst in the parking lot. I didn't actually pull the fuse out, just wiggled it around in case it was just a contact issue.
Old Nov 27, 2006 | 03:21 PM
Might want to pull the related fuses OUT and look at them before thinking it's a motor.
Old Nov 27, 2006 | 04:33 PM
Dave Hamby's Avatar
Can you tell me where to find the fuses and also where the access is to the blower motor?
Old Nov 27, 2006 | 05:27 PM
Fuses are located in the fuse block. Check out this online 300ZX manual: http://www.300zx.co.uk/cgi-bin/manual.cgi
Old Nov 28, 2006 | 10:31 AM
Dave Hamby's Avatar
Pulled the "AIRCON BLOWER" Fuse and it was in perfect condition. Are there other fuses relating to the blower motor?
Can you tell me where the blower motor is located and if there are any instructions on accessing / replacing it.
Old Nov 28, 2006 | 10:40 AM
Old Nov 28, 2006 | 01:07 PM
Dave Hamby's Avatar
Thanks for the link. I have used that one and a couple others that were on the General z32 info link but none of the layouts tell me where to access the Blower motor (from inside or from engine compartment). Nor can I find a thread giving instructions to actually pullout and replace (or test and reinstall).
If you can hook me up with a few short recommendations, that would be great.
ol55
Dec 17, 2013 02:36 PM
J-cubZ
Sep 10, 2010 03:19 PM
drftrzx
Sep 11, 2008 09:02 PM
nuzxowner
Feb 13, 2005 06:38 AM
GenHawk
Jun 5, 2003 12:06 PM
