400hp 280ZX Turbo
Guest
Posts: n/a
400hp 280ZX Turbo
I have just purchased a 280ZX Turbo and i would like to get it up to the 400hp mark at the wheels. Any suggestions on what to buy and in what order? Or any suggestions for things that "could work" that could be pulled from a different model car? I know that i will need an intercooler and boost controller, but are there other things that i should get first?
Any input will be greatly appreciated
Guest
Posts: n/a
Re: 400hp 280ZX Turbo
In order to get it to the horse power that you are looking for it will cost you a bit. Plus if you are asking what to do first than you probably havent done anything like this before. Find a mechanic in your area that specializes in the z car. They will know what you should do. If you really want to keep the in line 6 or drop in a small block v8. Those are the first ?'s you should ask yourself. And how much time and money do you have? There are lots to do to your car if it is in good shape to add horses, but 400 is a lot to ask for if you are on a budget.
Good luck
Killer
Good luck
Killer
Guest
Posts: n/a
400 hp at the wheels isnt that hard to get to. Currently im pushing around 315hp and 338tq but that will soon change once im done with the essentials (quaife lsd) Ive got a tape with an old 180 with the 83zxt engine bored out to 3.1 pushing 1600hp soooo.. me no think its that hard!
thanks,
franklin
thanks,
franklin
Guest
Posts: n/a
400 at the wheels equates to about 480 at the flywheel. IMHO that is going to cost you to make that much and still be reliable. Sure you could get it that high by skimping, but when one critical part craps out, you will have wasted your time and money. IMO a mild SBC would be a lot cheaper to get those numbers reliably.
Guest
Posts: n/a
Hi
I agree with "triple" if your on a budget the SBC might be a more economical option then the turbo. BTW you also have to consider beefing up the chassis and drivetrain and that's going to cost about the same as the power.
Toronto Ontario
Toronto Ontario
Guest
Posts: n/a
Well, if you are only shooting for a 400hp car, the current setup of a 280zx Turbo, CV halfshafts and r200 differential will be just fine. For a v8 conversion, that much power is really cheap. Its not so much that you need a 2000 dollar callies crankshaft for example. Mostly stock parts should be able to handle that much power. Heads, and a Cam will easily get you to the level you want. As for the transmission you can go with a T5 fivespeed out of the older camaros with v8s and those are not expensive at all. But if you plan on putting out more power later, you might want to think about getting a T56 six speed which will be slightly more expensive. What I am trying to say is 400hp is extremely easy with almost stock parts in a SBC and the added weight is miniscule. It is like 100-150lbs. Plus if you set the motor in the proper position, the shorter v8 gives the car almost a 50/50 weight distribution which as many know is very ideal.
anthony
anthony
Are you talking about a balanced crankshaft? And a performance cam is really not nessisary. Maybe it can be useful, but most people don't bother with one. A proper fuel system and larger turbo is where to focus on.
A stroked turbo is also not nessisary. You probably want the stock stroke for better high rpm response. Plus you don't want to raise your compression too much. Stroking an engine costs a couple thousand by itself.
400 hp 280zx turbo
I think 400 hp should be reachable, but alot of mods must be done or considered. First, aftermarket engine management. You will need either a piggy back computer to help out the stock ecu to manage fuel and air, or go all the way with a stand alone system like TEC-II or Haltech. Second I think would be fuel delivery. You will need to have larger injectors. I currently am running 12 injectors staged so I don't run out of fuel under boost. You should also think to add a larger fuel pump, maybe larger lines, and a pressure regulator. You don't want to lean out under boost. Third, larger turbo. I have experienced with a few, and the T04E's or even a T-60 with the right wastegate should be able to supply enough boost. Fourth, a nice head gasket and bolts. I have a HKS metal headgasket and ARP head studs to be safe. My project should be completed hopefully before summer. I'll email you if you want to let you know how it went.
Guest
Posts: n/a
killer is right you need to know what to look for in your car. I have an 81 280zx non-turbo, but if you are looking for a mechanic that can tell you what you need to do. there is one in Here in Ventura, Ca who only fixes Z's and as far as I know he has the most knowledge on those cars that I have ever met. His name is Mike Sherfy and if you want to give him a call or whatever here is his # 805-646-9644, maby on the phone he could help you out.
Guest
Posts: n/a
I think you can do it.
Your going to need a programable fuel computer ofcorse, head porting and lots of intake work is a must and a set of 73lb injectors. I would have a cam ground once you have flow numbers for the cylinder head and intake. Then go with a 60-1 or maybe a TSO4 on the turbo. These are the must haves along with a hi flow intercooler and fuel system good for 800hp. You can do it you don't need a RB or SBC. Good luck.
Well now, how much power can the Nissan pistons and rods take? I think 800hp might be beyond their limits. If you go that far you might have to replace the pistons and connecting rods.
350hp is typically the limit for using the stock Nissan L-series turbo block and head combo. Its a pretty strong engine, but not that strong!
Guest
Posts: n/a
Nissan rods, properly prepped, will live in the 600 hp range. Bob Sharp and Paul Newmans cars from the 80's used stock rods.
The block is not a weak link at all, the weakest link in the L series engine is the rod bolts, and a call to ARP is a 50 dollar fix.
A stroker is not to bad, but you need to come up with a set of 240 rods, preferrably the 9mm rod bolt variety, and then get forged pistions made.
Run a T04E/T3 hybrid with a 60 trim or larger compressor wheel, and get some decent fuel management, and you are there.
My turbo made 415hp and 473ft-lbs on its previous owners car. It was a stroker motor by the way.
A properly built L6 will last a long time, and make plenty of HP, it just costs a little money. Your best bet is to find someone who has done it and see what they did and do the same thing.
As an added bonus, I like the look on someone's face when I tell them I have a 6. If you have a V8, they expect your car to be fast.
DUBAUDIO
Feb 1, 2012 07:47 PM
benny127
Sep 13, 2010 12:13 PM
wdpp8ntba11er
Apr 10, 2002 06:54 AM
280z, 280zx, 81, boost, convert, cost, fuel, gain, hp, management, safe, smallblock, standalone, turbo, v8
