400hp 280ZX Turbo
Old Apr 10, 2003 | 11:28 AM
Are you talking about a balanced crankshaft? And a performance cam is really not nessisary. Maybe it can be useful, but most people don't bother with one. A proper fuel system and larger turbo is where to focus on.
A stroked turbo is also not nessisary. You probably want the stock stroke for better high rpm response. Plus you don't want to raise your compression too much. Stroking an engine costs a couple thousand by itself.
Old Apr 11, 2003 | 10:50 PM
81280zxtc's Avatar
400 hp 280zx turbo
I think 400 hp should be reachable, but alot of mods must be done or considered. First, aftermarket engine management. You will need either a piggy back computer to help out the stock ecu to manage fuel and air, or go all the way with a stand alone system like TEC-II or Haltech. Second I think would be fuel delivery. You will need to have larger injectors. I currently am running 12 injectors staged so I don't run out of fuel under boost. You should also think to add a larger fuel pump, maybe larger lines, and a pressure regulator. You don't want to lean out under boost. Third, larger turbo. I have experienced with a few, and the T04E's or even a T-60 with the right wastegate should be able to supply enough boost. Fourth, a nice head gasket and bolts. I have a HKS metal headgasket and ARP head studs to be safe. My project should be completed hopefully before summer. I'll email you if you want to let you know how it went.
Old Apr 29, 2003 | 01:39 PM
Well now, how much power can the Nissan pistons and rods take? I think 800hp might be beyond their limits. If you go that far you might have to replace the pistons and connecting rods.
350hp is typically the limit for using the stock Nissan L-series turbo block and head combo. Its a pretty strong engine, but not that strong!
AndyZ32
May 6, 2012 05:24 AM
DUBAUDIO
Feb 1, 2012 07:47 PM
benny127
Sep 13, 2010 12:13 PM
jtmny1999
Aug 1, 2003 06:44 PM
wdpp8ntba11er
Apr 10, 2002 06:54 AM
