35-pin connector to control unit
So I'm trying to test out a bunch of stuff in the car and following the FSM. I just disconnected the 35pin connector from the control unit under the dash. Only to find out there aren't 35 pins, any ideas to why it looks like this and why the FSM tells me to measure stuff that this connector doesn't even have. (for instance page FE-25 testing throttle valve idle position.)
35 pins
Technically it is a 35 pin connector, some slots are not pinned, most likely for options you do not have. What year and options is your car ? The FSM's do cover Canada and California options, so you might just be looking at the wrong diagram.
Mine is a european 280zx 2+2 from '81 non turbo
I still have a repair manual from the EU here so I'll be checking that one tomorrow (it's 00:43 right now so bit to late to go tinkering on the car)
the weird thing is, there are pins on the ECU that are not one the connector and same thing other way around...
Repair manual didn't help me... also a different connector :s
Yes, i know the FSM clearly numbers every pin. But it told me to measure pin 29 and 30.. while I don't have a pin 29. (just an example) It was for the throttle valve positions. But allot of other things I wanted to measure out had similar issues, pins in the book that my connector doesn't have.
And just look at how few pins my connector has, and how few actually connect to the ECU
Mike86NA
Feb 3, 2005 05:55 AM
Mike86NA
Dec 29, 2004 06:18 PM
