280zxt Running alittle rough (idle)
Old Jun 7, 2011 | 05:00 PM
Hamer007's Avatar
when at idle my car literally shakes all over the stick shift rocks back and forth basically feels like a 400hp muscle car, although its cool, i think its hurting performance and gas mileage.
Any ideas?
Old Jun 7, 2011 | 05:35 PM
Engine mounts?
Old Jun 8, 2011 | 01:22 AM
Lupe's Avatar
My Car Did That For While Until Finally My Crank Pulley Fell Off. Thats Why Mine Was Shaking But Thats Just Mine IDK How Yours Is>
Old Jun 8, 2011 | 04:28 AM
JSM's Avatar
JSM
I would lean to this too. Also, check your mounts and trans mounts as well.
Old Jun 8, 2011 | 07:26 AM
Hamer007's Avatar
Engine mounts are good, i checked those. Ive heard crank pulley have issues on these motors, i might wiggle that abit.. i dunno lol
Old Jun 8, 2011 | 08:25 AM
Before we all take stabs in the dark, how about some more info?
When did this problem start? Right after the battery cable incident? (https://www.zdriver.com/forums/280zx-s130-forums-77/280zx-electrical-problem-any-help-32722/)
Does the car run fine except at idle?
What is the idle RPM?
Have you tried checking:
Timing?
Spark Plugs?
Wires?
AFM?
CHTS?
Vacuum leaks?
Old Jun 8, 2011 | 12:21 PM
When did this problem start? Right after the battery cable incident? (https://www.zdriver.com/forums/showthread.php?t=32722)
Timing?
Spark Plugs?
Wires?
AFM?
CHTS?
Vacuum leaks?
Boring..... maybe there are too many light bulbs on one side of the car and it's throwing the weight distribution off.
Timing.... pppffttt....
I do like the spark plug wires theory though. Kinda like my light bulb "stab in the dark" as you call it.... It's gotta throw the balance off if you've got all six on one side. Try moving three to the other side. You might need to tap new spark plug hole into the combustion chamber though.....
See "stabing in the dark" might just find us a solution!
Old Jun 10, 2011 | 02:33 PM
Hamer007's Avatar
LOL FRICFRAC!
this was before the battery incident, all hoses, wires, and plugs were changed. i did the vacuum tests and none changed idle, it idles at 750, umm i dunno what afm and chts its?? lol. timing isnt checked but i will have to some time.
Last edited by Hamer007; Jun 10, 2011 at 02:34 PM. Reason: didnt know how to quote till now
Old Jun 10, 2011 | 02:35 PM
Hamer007's Avatar
LMAO i like your theory!
nawednoori
Sep 2, 2014 09:39 AM
mikep
Sep 28, 2007 07:33 AM
tehweej
22
Jul 9, 2007 09:52 PM
91Zman
15
Oct 24, 2005 07:08 PM
chrisc0623
Dec 14, 2003 09:20 PM
