280zx injectors
Old Aug 11, 2008 | 07:38 PM
ZBRICK's Avatar
280zx injectors
Hello all. Looks like I will be replacing the injectors in my 82, na.
Are ther any write-ups on this?
Old Aug 11, 2008 | 07:49 PM
Niku-Sama's Avatar
eff good grammar
its pretty easy i wouldnt need a hayes manual even for it. just get the right injectors, a injector seal kit and mabe new retainers (if yours are cracked) and swap em out
Old Aug 11, 2008 | 08:08 PM
ZBRICK's Avatar
Thank you, I will get the injector seal kit and new retainers. I don't want problems down the road.
There are so many injectors to choose from, at various prices, it is hard to decide which to order. The link from a few days ago, regarding where to get z parts, was helpful when looking for he injectors.
Helpful for me though would be a step by step write up. I have search this fourm with out any luck.
Old Aug 11, 2008 | 09:44 PM
There's a write up in the Haynes manual.
#1... Disconnect fuel pump harness in hatch area.
#2... Crank car a few times to alleviate fuel pressure.
#3... Pop hood, disconnect injector wiring clips, and remove the 8mm injector retainer bolts.
#4... Loosen & remove power steering belt, followed by the idler / tension pulley.
#5... This is my own way, but makes life easier: use 2 12mm nuts back to back & tighten them down on the stud at the idler pulley & remove pulley.
#6... Remove / disconnect all other hoses for the fuel rail & pull fuel rail out.
#7... Remove & replace injectors.
Old Aug 12, 2008 | 03:43 AM
280zx2by2's Avatar
Haterade by da gallon!
also dont be an ediot like me and connect the fuel lines to the fuel rail the opposite way.... took me 2 weeks to figure out what was wrong
good luck (i hear most people on hybrid cant get theirs to seal on the first try) but we here at Zdriver are the shiznit so you should be good
also you might want to replace the electical harness connector thingeys... easy to do with the replacement connectors, heatshrink insulation, and a heat gun(or a hair dryer night work) just label the wires... one is black i think but i did it to be safe and splice and shrink..
Old Aug 12, 2008 | 10:27 PM
michanic220's Avatar
i never had to loosen any of my belts?
but mines a 82. it did have a bolt on the other side of the engine but i cant remember what it bolted to. it was a lil above the alt wire.
Old Aug 13, 2008 | 07:23 AM
^^^ Ah yeah... skip step #4. You don't need to remove the pulley, but you will need to remove it's top stud to get the fuel rail off.
Old Aug 13, 2008 | 11:59 AM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
Yeah i did this on my NA and it was SUCH a pain in the butt to get into the small spaces because I didn't even take the rail off Hahhaha those were the days...Do yourself a favor and take off the rail.
Old Aug 13, 2008 | 02:54 PM
Niku-Sama's Avatar
eff good grammar
i was wonderin
i am still trying to find a decent set of injectors
post #777, must be lucky
Old Aug 13, 2008 | 04:09 PM
ZBRICK's Avatar
Thank you everyone. Mine is an 82 and it has rack and pinion - not power steering. I am going to remove the fuel rail even though it is tempting to leave it on.
Looking at the fuel rail, it is attached to the front of the engine with a bolt that also attachs other parts. Maybe it the altenator.
this site:
http://www.nissanpartstore.com/catal...issan&md=280ZX
Has numorous fuel injectors. Granted some are for turbo and na, but why do you suppose ther is suh a wide difference in pricing? Is the cheapest one any good and do you think the more expensive ones are better?
Old Aug 14, 2008 | 03:55 AM
Get Beck/Arnleys...best ones I have ever had. www.rockauto.com. And also look into an aftermarket fuel rail. Save you some headaches down the road. I really hate the stock trombone fuel rail. lol Life is so much easier with the aftermarket one. I can have the rail off...in 5-10 minutes. Good luck though man..we are pulling for you.
Old Aug 14, 2008 | 07:42 AM
Red-Eye's Avatar
Can you show us a pic of your aftermarket fuel rail? And where did you buy it from? Thanks...Robert
Old Aug 14, 2008 | 03:12 PM
ZBRICK's Avatar
Thank you, men. Time to get this project spraying (so to speak), I just ordered the injectors and rings.
81datsun
May 23, 2023 06:28 AM
zbogo
Sep 23, 2012 11:26 AM
Duke
Nov 4, 2011 05:40 AM
Maloney
May 20, 2011 11:21 AM
DW280zx
Dec 7, 2007 11:12 AM
