280zx completely shut down hitting railroad tracks
Old Mar 13, 2013 | 04:58 PM
Hamer007's Avatar
ok so i was driving over railroad tracks earlier today and instantly car shut off rpm hit 0, whole car killed itself. I still have interior lights and headlights stuff like that... radio died, cigarette lighter (phone was almost dead) fuel pump is off, engine wont even crank, what did i bump or mess up to cause this all to shut off??? its like i lost all accessories hmm
everythings been fine and dandy for awile now, this is crazy lol
Old Mar 13, 2013 | 05:10 PM
henrycas's Avatar
seems that your alternator and battery died
Old Mar 13, 2013 | 05:12 PM
henrycas's Avatar
or maybe fusible link.
borini63's Avatar
Lose Battery cable or blown fusible link!!
Old Mar 13, 2013 | 05:23 PM
Hamer007's Avatar
battery cables are all tight took em off and reattached, alternator is fairly new. under 1k miles. battery is few months old. ill look at fusable links some more but look closer
Old Mar 13, 2013 | 08:24 PM
BlueKitsune's Avatar
Intrawebz Wizard
I'd check the grounds to the engine as well. Mainly the one off the battery cable to the starter.
Old Mar 13, 2013 | 08:36 PM
Hamer007's Avatar
those are good and clean.. im gonna start tracing wires with a power light i guess tomorrow, something had to bump loose or short when i hit the tracks...
Old Mar 14, 2013 | 06:07 AM
zedsdeadbaby's Avatar
Smack the panel by your computer. If that doesn't work, shake your injector harness.
Old Mar 14, 2013 | 08:12 AM
MurphyEF's Avatar
Was the battery secured? If not, it might've grounded out to the hood.
Old Mar 15, 2013 | 09:16 PM
i bet a plate fell over in the battery. pull the cables and check the voltage. no point starting in the middle of the circuit if you dont know the source is any good.
Old Mar 16, 2013 | 08:05 AM
Lesnocker's Avatar
Bad ignition switch?
Old Mar 18, 2013 | 07:45 AM
77280ZX's Avatar
I d doubt the battery is bad if you still have lights. Check the connector harness to the ecu.
Old Mar 27, 2013 | 08:55 AM
mrprofile's Avatar
voltage drop test the cables, if you have a multimeter set it to volts, connect the negative to the battery negative post and connect the positive lead to a good clean grounded engine part, start the engine, if the volts jump high to 12v or so, then you have a bad ground, but if they stay low around .1-.5v you are good.
zx2801979
May 2, 2015 04:21 PM
slownrusty
Sep 10, 2013 11:07 PM
TTZ32
May 29, 2006 04:23 PM
elmacho0326
FS: 300ZX (90-96)
Sep 22, 2005 12:49 PM
BMK280Z
Oct 23, 2004 03:32 AM
