2.5k ohm resistor?
Old Feb 19, 2008 | 04:15 PM
duowing's Avatar
NisTuner
2.5k ohm resistor?
I've seen in the Haynes for the 280ZX and at points in the FSM for the Z31, for testing things like throttle position sensor, adjusting CO%, etc. They show for example to unplug the CHTS and put a 2.5k ohm resistor onto the connector so it's feeding the ECU a constant signal to adjust the idle mixture by. What are these called, and can I get them at the auto parts store? Would I just look for a resistor?
Old Feb 19, 2008 | 04:38 PM
KasbeKZ's Avatar
Pr0n Addict
it's called a 2.5K ohm resistor at radio shack. they usually have a huge wall of them. should be less then a dollar if you can get just one
Old Feb 19, 2008 | 04:40 PM
duowing's Avatar
NisTuner
cool, thanks for the info. I'm gonna have to pick up one.
Old Feb 19, 2008 | 05:46 PM
SpeciallySpiked's Avatar
I'm a Registered User!
if they don't have just one of that exact number. Put 'em in series! Yay for physics
Old Feb 20, 2008 | 10:23 AM
duowing's Avatar
NisTuner
What do you mean by put them in a series? Like you'd connect a lower value resistor to another resistor, then to the harness to make 2.5k ohms?
Old Feb 20, 2008 | 04:07 PM
Exactly.
Hard to see but there are two in series there. Most likely the resistors you find at Radio Shack will look very similar.
Resistors in series just add together.
1.5K (ohms) + 1k (ohms) = 2.5K (ohms)
carlos48
May 17, 2013 04:46 PM
Zcarlover01
Oct 14, 2008 06:28 AM
duowing
Apr 8, 2008 08:37 AM
vrocious
Sep 27, 2007 06:52 AM
nzz
Feb 20, 2002 04:59 PM
