1982 zx turbo almost starts. *Movie*
Old Apr 2, 2015 | 05:14 AM
Alexander Kihl's Avatar
Question 1982 zx turbo almost starts. *Movie* *Solved*
Hi!
My name is Alexander and I live in Sweden.
I own one of two original turbos here in this country ( I had the other one 15 years ago), so there is not so much info here, about the turbo models.
I got my car in 2007. It was bought new in the USA by a Swedish man, that brought it here, when he moved.
Later he was sick and died.
I then took this car over.
It would not start then, but I found it was a clitch in the cpu connector, so I got to run nicely back then.
Due to family life and so on, I didn´t have the time to work on it anymore, so I stored it, I drove it there. This was in 2009.
Two days ago I picked it up, I felt like doing something with it or pass it on.
I took it home with trailer, washed it up and so.
Checked the essentils, like oil and stuff, then tried to start it.
Nothing.
I thought it was the clitchy connector to the cpu, but it was not (I can tell, because when I crank it, the rpm meeter moves a little, when it is ok, when it is not, it lies dead)
I then changed the fuel in it, just to outrule it was old, I also took away all the electric connectors in the engine compartement, checked, blew them with air and used electro-protect.
I also looked at distributor cap, spark plugs, lines and all I could think of.
Nothing wrong.
Removed plugs and they were all dry and looked normal.
I then suspected something with the fuel pum. Removed the connector from the starter and held key in "start" position. Then there was no sound from the fuel pump. I then gave it directcurrent from the battery to let it run all the time.
No difference.
I then measured the injector connector with a small lamp, and it flickers a little (see film) so I suppose the injectors gets the signal. Cold start valve disconnected (as described in my Haynes book).
The car runs fine on starter fluid (?), so it has a spark.
The problem is obviously fuel.
I have limited knowledge about the fuel pressure regulator.
In the book it says how to test it, but many tests assumes that the car is running.
Would a faulty regulator prevent the car from even starting?
If I crank it now, it "puffs" I mean it tries to start, but does not. This when I try to start it without depressing the gaspedal, like I should.
When I depress the pedal, it tries harder to start, almost runs, but not.
This is also on the film.
I realise that I can troubleshoot all components with the help of the book, but I feel like I could use som help.
I feel a bit tired of my car, at the moment...
Anyway, if there is anyone who has an idea, I would be very grateful!
Also, I´m sorry if I misspell or name things strange, I am from Sweden:
Here is the film:
Old Apr 2, 2015 | 05:47 AM
borini63's Avatar
I think you answered your self.......Fuel Pump!!!!
Try to find another fuel pump and see what will happen.
Old Apr 2, 2015 | 10:59 AM
Hi!
Thank you for answer.
I went back to my garage and continued, after cooling off a bit
I tried it agan, for no reason and imagen my surprise when it actuelly started.
It went like crap, but it ran on its own!
I then started to see why it was not running on all cylindres, by removing one spark plug connector at a time.
It did not respond to 3 of 6 cylinders.
Ok, I thought.
While I was standing there, with engine running, it started to go more even.
Now 4 cylinders.
And suddenly it was only one cylinder left, not running.
Hm.
I tapped the injector on that one and voilá! All 6!
As far as I can tell, the problem was that the injectors were siezed somehow, from standing still for so long.
I have worked with cars for over 25 years, but I have never had one acting like this.
I guess there´s something new to learn every day.
I even took it out on the road and refreshed my memory of what an amazing car this is
Anyway, thanks!
Here is a new video of it running:
Also some pics
Attached Thumbnails 1982 zx turbo almost starts. *Movie*-20150402_180120.jpg   1982 zx turbo almost starts. *Movie*-20150402_180127.jpg   1982 zx turbo almost starts. *Movie*-20150402_180147.jpg   1982 zx turbo almost starts. *Movie*-20150402_180201.jpg
Old Apr 2, 2015 | 04:35 PM
Photoguy360's Avatar
Old car start up procedure
Next time try this when starting an old car it might help.
I have a 1983 280z turbo currently non-running, Bad ECU.
nice job
File Type: pdf
ThaPimpShrimp
Jan 6, 2012 04:35 PM
Lostsoul
May 31, 2010 06:11 AM
mickey_bigdaddy
May 12, 2009 08:52 AM
thunderz
Feb 12, 2006 06:46 PM
ZxWC
Apr 15, 2004 09:07 PM
