Z31 LSD - Which half shafts to use
Old Oct 29, 2008 | 12:40 PM
CWHammer's Avatar
Under My Car... brb
I spent an hour or so going through all of the posts that came up under the search for "Z31 LSD" and couldn't find anything that clarified which half shafts were needed to do the swap. It seems that if you have an earlier ZX, 79-81, that you have to get the shafts from the donor car. Does that also ring true with an '83 2+2? I have the CV joint style shafts with the 6 bolt flanges. Will they bolt up to the Z31 diff?
Old Oct 29, 2008 | 12:49 PM
The 1987-89 Nissan R200 clutch LSD uses the stock R200 280ZX half shafts. You do not need (and I think can not use) the Z31 half shafts.
Only the super rare 1988 VLSD unit has unique shafts and you must use the Z31 shafts, modified to fit the 280ZX. Not all 1988 LSDs were that type though. It is unlikely you will ever come accross one.
Old Oct 29, 2008 | 12:57 PM
CWHammer's Avatar
Under My Car... brb
Thanks Bleach. Now the next question, has anyone used the Subaru diff in their Z? Ii keep seeing quick blurbs on doing this but I haven't seen any real info.
Old Oct 29, 2008 | 01:12 PM
you mean has anyone used an R160 LSD in their Z? hahaha
not that I've heard. Its more of a Datsun 510 thing for those with a non-turbo 4-cyl L-series.
Old Oct 29, 2008 | 01:33 PM
CWHammer's Avatar
Under My Car... brb
That's all the 'boobaroos have is a 160? I thought I saw reference to 180s and 200s. Makes me wonder what they slap under the WRX STi AWD rearend. It must be pretty stout if they are easily tweaked past 400 bHP. Of course that power is split between all four wheels.
Old Oct 29, 2008 | 01:45 PM
The only Datsun compatible LSD I know of is the R160. If there is an R200 LSD, then it must be a different housing that does not work in the older Z-car.
The S14 has an R200 LSD but it doesn't fit a Z.
Old Oct 29, 2008 | 03:35 PM
260zturbo's Avatar
Stupid Hurricanes...
might as well go get find a q45 and grab the r230 lsd. the s14 had a short r200 lsd
Old Oct 29, 2008 | 05:42 PM
reddzx's Avatar
This thread should give you most of what you need to know.
http://forums.hybridz.org/showthread.php?t=114798
The VLSD differential only came in the Z31 in the 1988 Shiro (SS) model. The R200 CLSD was avaliable only in Z31 4/87 to 89 Turbo cars.
Old Oct 30, 2008 | 05:48 AM
CWHammer's Avatar
Under My Car... brb
Thanks guys, that clears up a lot of confusion. I'm trying to get to the boneyard this week to see what I can find. Not many good choices for imports in the Motor City.
Flacster
Sep 29, 2024 05:55 PM
Bleach
46
Jul 16, 2014 09:01 PM
GNRick
Jul 11, 2014 11:49 AM
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
borini63
Nov 4, 2011 12:34 PM
