Wont start sometimes
Old Jan 25, 2011 | 08:36 PM
zordietrying's Avatar
When my 82 280zxt is cold it will start every time but if i drive it, shut it off for a few minutes then go to restart it, it wont start. I try a few more times then it will start and sputter for a second then die. I start it again and give it gas and rev it a little then it runs great. I think its vapor lock but I'm not sure. I run premium 91 octane gas, and it has a pallent fuel rail. You guys have any ideas? And if it is vapor lock what can I do about if?
Old Jan 25, 2011 | 09:11 PM
Sounds familiar... https://www.zdriver.com/forums/280zx-performance-technical-79/update-30723/
A motor needs 3 things to start:
-proper air
-proper fuel
-proper spark
Do you have spark at each cylinder? Are all fuel injectors spraying?
Vapor lock is not a common problem on the L28E, and even less likely to occur at ambient temps below 80-90*F.
And even less likely w/ a larger than stock flow like a Pallnet rail. Vapor lock was a problem on old school (like 60's/70's) carbs that use very little fuel pressure.
Old Jan 27, 2011 | 01:15 PM
Any ideas what it could be, maybe a little more specific? Or has anyone else had this happen?
Old Jan 27, 2011 | 04:03 PM
DUDE...
In case you missed the only other post on this thread...
-proper air
-proper fuel
-proper spark
ARE THE INJECTORS SPRAYING?
IS THERE SPARK AT EACH PLUG?
moorebl
Apr 14, 2011 03:28 PM
ZXT83
Oct 3, 2009 01:07 PM
dreamspawn
Dec 20, 2008 10:15 AM
JaYaYsSoHN
Dec 29, 2004 12:58 AM
rickyTT
Sep 26, 2004 06:11 PM
