Won't rev after turbo swap
Old Mar 18, 2007 | 01:26 PM
mikesz's Avatar
Just finished my turbo swap and the car will start but,not rev.Tested the afm and it is ok.All of the wiring is hooked up correctly,And the car will idle for a while and then die.
I haven't checked for vacuum leaks yet but,the engine sounds normal.If anyone can help me out.Please let me know asap.
Old Mar 18, 2007 | 02:38 PM
Could be timing, CHTS, AFM set incorrectly, non-spraying (stuck) fuel injector, etc etc etc.
Old Mar 18, 2007 | 02:40 PM
mikesz's Avatar
The injectors were just cleaned and tested.The afm came off a running zxt.
Old Mar 18, 2007 | 02:44 PM
Did you set the timing at 20 degrees w/ the TPS unplugged?
Pull the spark plugs. The tips will tell you what is going on (too rich / too lean / detonation).
jbtatro
Feb 1, 2014 01:20 PM
benny127
Sep 13, 2010 12:13 PM
TX49datZ
Apr 27, 2010 08:33 PM
Bleach
Mar 5, 2010 10:56 AM
johnsonsz31tt
May 7, 2008 07:27 PM
