Wont fire, electrical i think, help plz
Old Oct 15, 2004 | 09:19 AM
83 280zx 2+2's Avatar
I started my 1983 280zx 2+2 fine yesterday with no problems at all. it runs great with little or no problems at all in the engine.
although this morning i went out to start it and nothing happened. sometimes when i turn my car to the "on" position the electronics dont light up right away. my dash is all electronic. when i took my keys out and left my lights on my voice told me they were on so my battery cant be dead.
sometimes when i go to start it before letting it sit in the on position nothing happens. i think that my sensors are old because when i turn it on my oil pressure gauge takes a minute or so to work.
But this morning i went to start it and warm it up. nothing happened. the dash came on and i turned the lights on but the oil pressure did not rise. i think maybe i need new electronics, or maybe my battery doesnt work right or something.
It didnt even turn over or do anything. i dont think my starter is ruined either. i need help as soon as possilbe plz thanks.
Old Oct 15, 2004 | 09:39 AM
anlasak's Avatar
Do the lights dim at all when you try to crank her?
Does she turn over or "clicks" or nothing?
I would start at the battery,its possible for it to put out enough juice to power the lights and still not be able to crank.
A battery can have a dead cell and still read good.
Get a battery from another car or a friend that you know is hot,(the battery not the friend ) ,and see if that solves your problem.
If it does then I'd have that battery and alternator checked out.
Old Oct 15, 2004 | 09:40 AM
The oil pressure should never rise unless the engine has already started up and is running.
I think your battery is dead, or the battery cables need to be replaced.
Old Oct 15, 2004 | 10:12 AM
icice9's Avatar
Super Siver & Black Stud
your problem might just be your ignition switch.. had the same problem with mine so i just rewired it so now ive got a push button starter switch...
Old Oct 15, 2004 | 12:32 PM
on ya. The switch part went bad on my ignition too. On the back of the lock housing, there is a round white plastic part that screws on with two small screws. Its about $30 for a new one and is easy to fix. It sends the signal to the starter solinoid when you turn the key.
Old Oct 15, 2004 | 08:50 PM
rifleman502's Avatar
could be the fusible links, i just replaced mine with maxi fuses after an ignition catastrophe, note to self, NEVER REMOVE THE COIL RESISTOR...
Old Oct 17, 2004 | 07:02 PM
Dorifto's Avatar
Sounds like the fusible links to me - the same thing happened to my car.
Don't count on what I have to say though, cuz my car's an electrical nightmare.
And your battery didn't explode yesterday ...
Old Oct 17, 2004 | 08:40 PM
my fusible links are gone now
they look like this
Old Oct 18, 2004 | 09:25 AM
works
i figured my battery or fuses were the problem being that i think the battery is still stock and maybe the fuses are. but i checked out the problem the other day and decided that i needed a new battery.
So i bought a new one. still doesn't work, i said well maybe its the connection, and i went through and looked at the cables after all they still are stock.
i decided that new ones couldn't hurt with my new battery. after i take the old ones off and put the new ones on. it works like a charm. i think the cables just gave out on me.
But i probably should get a new fuse cause sometimes it has the same problems. thanks for all the input.
RHDave91
May 2, 2010 11:46 AM
cake872
21
Nov 4, 2007 08:52 AM
NismoPick
Oct 28, 2007 01:54 PM
nismo619
Apr 13, 2006 09:57 PM
BJ BISIG
Oct 11, 2004 06:10 AM
