what could cause a bad missfire when cold?
Old Jul 30, 2013 | 05:31 AM
aruiz714's Avatar
83 na 280zx. What could cause a bad missfire when cold? I accidently ripped the wire off the thermo switch could this cause it?
Old Jul 30, 2013 | 07:21 AM
Yessir...
There are 3 sensors...
#1: Water temp sensor for dash gauge
#2: Water temp switch for the aux fan
#3: Thermotime switch for the cold start valve (n/a only).
From the FSM (you should download it here: XenonS130 - S130 Reference if you haven't done so yet).
Old Jul 30, 2013 | 08:56 AM
aruiz714's Avatar
Thank you mr. Pick. I was going nuts.
Old Aug 9, 2013 | 07:20 PM
aruiz714's Avatar
Is the water temp sensing switch for the injector fan? It only missfires when cold once warm is drives amazing. Its so embarrasing leaving work with a bad missfire. Also the temp guage is at 3/4 at idle 1/2 on streets and 0 at freeway speeds what do those symptoms mean?
Old Aug 9, 2013 | 08:03 PM
Yes, as stated above.
Check cold start valve, thermotime switch, and air regulator.
Check the connection (ohm test).
Check coolant level.
With an infrared thermometer, check temp at thermostat housing at operating temp, the check temp at lower intake hose. If cooling system is working properly, you should see a 20*F-30*F temp drop.
Old Aug 12, 2013 | 05:00 PM
aruiz714's Avatar
How do I check the thermal time switch and cold start valve my computer is not working at the moment.
Brotha_Z
Nov 15, 2014 12:31 AM
Darcy Bekkema
Jun 11, 2014 07:21 PM
buellmaster420
Nov 29, 2012 07:24 AM
lcplusmc
Jan 5, 2011 04:46 PM
280zx2by2
Jun 7, 2008 08:18 AM
