weird noise car wouldnt start ?
hey every body .. i hadnt drove my 280zxt for about 5 days then i started it up , i let it warm up as i normaly do about 5 min warm up.. then i drove it down the road with pirde 1st gear 2 nd 3rd no problem i came to a stop took a left 1st gear shifted to 2nd then complete DEAD... i had to push my baby to the side of the road becuase she didint want to start.. i notced when i opened the hood there was a werid sound coming from the valve attached to the AFM ? i couldnt figure out wat was wrong this have never happend before.. the car did start and i drove it home... any ideas ?
the valves next to the AFM are the vacuum control modulators for the idle control and EGR valve's. Neither is likely to make your car quit like that though. If it happened going around a turn I'd suspect a loose connection or faulty wire somewhere. How long til the car started back up?
well i had to let the car sit becuase i was already late for work so p iarked it on the side of the road ..i came back to it after work was done 10 hours then the car started up just fine i will double check everything tomorow.. as its my day off.. and no i havent got my BOV yet..
im thinking its the my coil right now becuase i had a problem like that before on my 1983 280zx n/a/ ,,, i have bought a high performence coil.. drove around for about 50 miles then the same thing happened.. engine goes dead.. does any body know any high performence coils for a 1982 280zx turbo ? would hte ps20 coil work that motorsportauto sells ?
Distributor
When it dies, you should leave the key on and wiggle the connector on the underside of the distributor until you hear the injectors click once.
Then you can usually drive the car.........until the next warm-up cycle.
ok well i have been driving my turbo car alot latly but does any body know why in the h#ll that little vacum on the side of the AFM would sound like its about to explode and the car wouldnt start ? anyways i got awsome news !! NismoPick i got my Xs power Blo off valve on the car.. omg !!! its sooo loud !!!
why would jiggling the CAS connector make the injectors click?
Because the module in the distributor is experiencing an open circuit that occurrs because the potting or conformal coating of the electronics expands at a different rate than the metal traces.
Wiggling the connector can temporarily restore the connection..........until the next warm-up cycle.
The ECU needs the pulse signal from the spinning CAS wheel in order to know when to fire the injectors. An injector is not going to fire if the engine isn't spinning.
That all depends on which trace is cracked.
I've been doing it since these cars were new and I just thought someone would want a shortcut found in my 20+ years experience on this car.
If you want to refute me, you will have to get into component level discussion of this unit and understand how it works..............at the component level.
awww ok... anyways i got my turbo xs power blow off valve on and it sounds awsome ! im boosting to 10 psi switching gears at 4,500 rpm and u can hear it like 2 blocks away its loud... ! any ways i havent had any problems with that valve.. yet.. so maybe im in the clear ?
I figured explaining it would suffice as an explanation on an earlier post.
