TURBO questions
ok.... i thinki may have a surprise in store for all... but i need a few parts FAST! also some info... the parts i need FAST FAST FAST are the T fittinf for the engine that is the branch off from the oil system to feed the turbo oil... also the feed line would be nice but no big. does anyone have a picture and this part/parts for me? cuase right now i finally got EVERYTHING to do a good N/A motor to turbo motor conversion except the T fitting to supply the damn turbo oil... FUDGE. rob (ktm) was helping me out but he cant get to his car, i thought i found someone to sell me this piece on hybridz but after he asked if i want the oil feed line to he hasnt responded back... go figure?
also i picked up the echaust/intake turbo gasket as well as have a head gasket coming gonna go get a new oil pan gasket to. but the place didnt carry the gaskets for the wxhaust mani to turbo and the turbo to down pipe... where would you guys recomend to purchase these? im in a mad rush for the oil supply fitting so any one shine some light on me. if i can get this piece i may have a lil surprise for ya'll this or next weekend... thanks ya'll.... ps. go visit the auto show thread lol |
Let me guess,
You can go to MSA show and you want to get your car done in time. Take lots of pics and show us how the conversion turns out. Edit- you really like the auto show thread. |
go to turbo accessories
http://www.jgstools.com/turbo/index2.html they should have them here too http://www.atpturbo.com/ |
has nothing to do with MSA... has to do with a magical finish time of 2 weeks or less
cause today i went out got oil pan gasket head gasket valve cover gasket. all mobile one fluids for trans/diff (synthetic) gotta get oil still got mobil 1 oil filter exhaust/intake gasket. new cap rotor taylor hi-pro wires NGK platinum plugs new studs and nuts gonna change em all out today then for thurs and fri gotta remove intake exhaust oil pan oil pump and then install all gaskets new oil pan old intake new exhaust turbo downpipe turbo oil pump turbo fuel rail with FPR and injectors until i get an safc to use my pallnet fuel rail with DSM injectors turbo afm remove EFI harness from engine harness but in turbo harness put in engine harness ecu turbo plumbing driveshaft and im sure a few other things im missing and im gonna have it wired professionally cause i dont have the time patience or nerve to do wiring my self... plus its threw my best friends GF's dad so im garunteed quality work and price. SCORE! |
veynel thanks... but i dont know if your thinkin the same thing im thinkin of... the piece that screws onto the block of the engine i believe where the oil presssure sender unit goes (T fitting) so it taps into the pressurized oil system to feed the turbo oil. i saw T fittings and SS oil lines whihc is helpful but still not my urgent part needed
JGS should be able to give you the correct BSPT to NPT adapter and distribution block for the oil line and sender. The threads on the block is 1/8"-27 BSPT.
ahh..... k cool... man im no good at thread sizes and pitches... i know i will find a way to screw this up. i think.... i thik i need you to hold my hand on this one veynel. just tell me what i should ask from them lol. so i know im not gonna screw this one up. id much appreciate it.
SHUT UP! lol yeah...
why are things always easier than i think... where would you suggest taking this though out of personall experiences? |
NAPA. or if you don't have any near by, go to a hardware store or go to a hose / hydraulic fittings store. There's a huge warehouse here in SLC called "EVCO House of Hose" ( goin to the ho house :D ). They have every fitting / hose I could ever think of... and that's here in the West. I'm sure IL has tons of places like that.
i got napa 5 mins away... 3 turns. 2.5 miles. lol
alright... i guess im taking my oil pressure sender with me to napa and try to find a T fitting.. this is where teh oil supply line runs from right? so whats up with the wierd fitting on teh l28et that the oil filter screw onto? is that jsut for the oil cooler? or what? i should prolly get an oil cooler huh? couldnt i run it in the same system that the turbo is gonna be on? or you guys think that would be to much?
its gonna blow up snw :D.
I spent a lot of time on Hybridz doing research on that oil feed line. those threads don't all match from what I remember. This is not something to rush.
I got most of what I needed for a brand new stainless oil feed line but ended up going with the stock one because I couldn't get all the parts to match up at the T on the block. anyway, the local places in Washington are all run by idiots. I can't even get a plug for my intake manifold, much less a British pipe thread T block... even though the plugs I needed were only oil pan drain plugs... what did you decide on your oil feed line? -3 all the way or -4 with a reducer at the turbo? I did the -4 with the reducer. and I did get a BSPT plug that fit the block fine but it does not screw into any of the female connections on the T so they are not all the same thread. If they were, my setup would have been done. :( |
well... i wanted to SS but honestly... it would only be for looks and jsut cause to much headache... so i need to just get the T to fit inbetweent eh sender and its mount and then make shift some way to get a high temp (radiator type) hose on the T and snuggly. no pop offs. and what the hell do you mean reducer? lol -3 -4? que? if theres anything i dont know very well its piping, threading, and electrical.
its gonna blow up e... i plan on it blowing up. i just hope its not catastrophic and just blows the rings out or the pistons fail. im not gonna push it... just 7 psi maybe 10 when intercooled... then doing a rebuild with some new forged turbo pistons and rings maybe rods to. then i can go nuts. |
Eric,
Sorry I couldnt help you more, it looks like you've got everything allset though. I know it may not help now but I can get to my car this weekend for sure, so give me some details on any specific pictures you might need. Good luck |
umm... i got the T made up.... so now worry about that. but now i got a wiring harness problem... i got the ECU and harness turbo ones, but the connector for the TPS is either different or ****in gone... there is a plug by the injectors that is round has 4 prongs dont what that sh!t is for... and yeah, stuff doenst seem to match up. i mean, besides a knock sensor and boost sensor plug i figured teh harness connectors would be the same. idk im pissed about it and not sure what i want to do now....
pics!!!! you should know that by now snowy
Ohh ya like Skittle said......
http://i16.photobucket.com/albums/b1...picsorgtfo.jpg |
haha... you like that guy... well i have been talking to nismopick... and assuming the turbo and NA ignitor's are the same just in a different location i do need a turbo distributor and a turbo TPS... so can any one help a bro out? and i need the whole distributor (82 or 83) with shaft and the internal cas all that jaz.
so seriously.. if any one i mean ANY ONE! ( i know bleach has an extra motor sittin aroun ;) ) but really... i thought all my part scavaging was done... and i was wrong i need those 2 things... that should be it all stuff will be said and done... so i need help UBER fast. thanks for anyone with some answers. |
You wanna send me shipping $$$ and I will have it out tomorow or saturday. Its from an 83' turbo, exactly what you need.
TPS and distributor???? no shit ???? i can send out shipping money as soon as i get my money from teh ECU im selling should have it tommorow? dude youll be a life saver
you'll have more money from the trim too hahahahah
Rob |
