turbo with oil cooler or turbo with out
Old Apr 16, 2012 | 07:42 PM
studio110's Avatar
so the engine im using for my swap has only an oil line from the oil pressure sending switch. the other engine from a donner car has oil cooler and fan.do you have any luck with the engine with no cooler. any opinions .
Old Apr 16, 2012 | 07:57 PM
Any luck?
What exactly are you asking? Are you asking if you should use an oil cooler? If so, the answer is YES.
Old Apr 16, 2012 | 11:09 PM
Yes and if you paint it red your luck will tripple!
The 5sp turbo didn't come with the oil cooler but the automatic did.... If you are going to run and oil cooler make sure you use a thermal plate with it (similar to the thermostat in your radiator)
Old Apr 17, 2012 | 06:16 AM
studio110's Avatar
my question,would i be alright using the engine without the cooler
Any luck?
is the engine engine without the cooler acceptable and why .
Old Apr 17, 2012 | 06:21 AM
studio110's Avatar
is the thermal plate that black ovel thing by the engine inspection light and what is that any way?
Old Apr 17, 2012 | 10:35 AM
I'm still not sure what you are asking...
There are many 5speed 280zx turbos still on the road that don't have an oil cooler. I believe the reason the auto turbo had the oil cooler was because the auto is a 3speed, so the rpm's hang higher when cruising.
So yes, running a turbo (L28ET) motor without an oil cooler is still safe, though I do suggest running an oil cooler if you plan on doing any mods at all, especially if you plan to increase the boost. And if you swap in the turbo combo gauges, you even get an oil temp gauge. Or you could just install an aftermarket one.
Old Apr 17, 2012 | 12:49 PM
studio110's Avatar
Thanks for your knowledge, i was looking for some reassurance that i would be OK not using a oil cooler. i am going to go with a manual tranny.
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
teamadidas
Jun 2, 2005 04:41 PM
jvanen
Jul 12, 2003 02:43 AM
