Turbo motor, N/A Tranny??
Old Feb 15, 2005 | 12:04 PM
s/cL3.0's Avatar
Bleach is my Hero
If I use a turbo motor and a N/A tranny {5 speed} I can still use my lightwieght flywheel and centerforce III clutch right??? Will I need anything else??? thx Also will it bolt right in?? thx again
Old Feb 15, 2005 | 01:22 PM
yes, it will bolt right in. Same clutch setup is used on both. Use the non-turbo driveshaft and differential with your NA transmission. If this was an NA car to begin with, then you're set.
If those clutch fingers are a lot stronger than stock, it is highly suggested that you install all new clutch hydralic hardware. New or rebuilt clutch master, slave, and rubber hose. The added force might cause the old used system to eventually burst somewhere.
Old Feb 15, 2005 | 02:06 PM
s/cL3.0's Avatar
Bleach is my Hero
cool thx...Cant' wait to get my new tranny rebuilt..Mine has been dry for 6 weeks now... I really do not like shifting it past 6000 rpm but the v6 mustangs, and S10's will not leave me alone...
Old Feb 16, 2005 | 10:37 AM
Dorifto's Avatar
S10s are a threat to you? Hmmm ...
My '84 Mustang V6 holds its own on the street ... bone stock, with a 3-speed auto. Soon to be turbocharged
I've always shifted around 5500rpm, as I believe the powerband drops significantly past there. I dunno, your car could be different ... or not have valve float like mine.
Old Feb 16, 2005 | 01:23 PM
How does an '84 Mustang V6 auto compare to a 94 Mustang V6 auto? ...because I've driven a 94 and it was dog slow. The Mustang V6 5-speed can hold right up with my NA 280ZX 5-speed.
Old Feb 16, 2005 | 06:48 PM
s/cL3.0's Avatar
Bleach is my Hero
Nothing is a threat they just think that they are hot ish... Today I got it up to 120mph on a 2001 ricer altima beat it by a good two semi's with trailer legnth..It was pretty funny
Old Feb 16, 2005 | 09:11 PM
Dorifto's Avatar
Excellence, s/cL3.0 ...
I guess what I meant by "holding it's own" on the road was that it beats most ricers out here. When everybody else's car drives like you're autocrossing a UPS truck, you tend to have an edge. There's really no difference between an '84 and a '94, aside from power delivery, which is where my car excels (the '84 has slightly more torque over a broader range than a '94 auto ... the 5-speed has me by about 30 ft. lbs. I think)
koprutzxt
Sep 5, 2012 07:37 PM
johnsonsz31tt
May 7, 2008 07:27 PM
attworth
FS: 300ZX (84-89)
Dec 30, 2006 01:34 PM
bardabe
FS: 300ZX (90-96)
May 15, 2005 07:50 PM
EricMcIntire
Nov 26, 2004 12:54 AM
