Turbo Coil
Old Aug 4, 2017 | 07:43 AM
DREAMYZ's Avatar
Turbo Coil
Is there a direct replacement.
After looking at the FSM specs.
Primary Ohms should be 0.63 to 0.77
Secondary Ohms should be 7.0 to 8.6 K
Im getting 1.4 Ohms on Primary / 7.9 on Secondary
Primary looks to be almost double.
I have 3 turbo Coils that I pulled of junkers, and all of them
dont even come close to Factory specs.
Would this make much difference, Because it seems like when Im pushing the car hard, it seems to want to start breaking up a little towards the top of the RPM range.
Old Aug 4, 2017 | 10:03 AM
rogerz's Avatar
Grumpy & Helpful
ohms on a coil mean nothing except at least you have continuity. hook a plug up to the coil. make and break 12 volts and see if you get spark. if you don't know what all that means take electricity 101 and learn how a coil works. no car likes being pushed to the redline for a long period.
Old Aug 4, 2017 | 10:37 AM
DREAMYZ's Avatar
So as long as I can read continuity through the coil, no matter what that happens to be, then all is good, OK.......... sure got you. Out of spec means nothing. Let me throw this FSM out the window.
I meant top of the Gauge, not range, around 4500, it starts breaking up a little.
Thats why I thought maybe the coil was breaking down.
Old Oct 9, 2017 | 10:59 AM
DREAMYZ's Avatar
Follow up,
I bought a new Coil, it is within specs, does it help, as far as I can tell not really, but its within specs.
ColeParker
Oct 9, 2014 11:56 AM
tamug92
Mar 19, 2013 04:43 PM
studio110
Apr 7, 2012 06:38 PM
KuRupT_Z31
Feb 23, 2011 11:32 AM
Z*Tech
Jun 19, 2005 04:26 PM
