PurePontiacKid |
12-16-2009 08:59 PM |
Of course, since the 280ZX system is so complex, you need to download Asteroids to your laptop. But simply doing that won't do it. You need to beat levels to be able to tune different things on it. like beating first level lets you adjust the ECU within stock levels. Beating second level allows you to slightly alter the fuel tables a little more. But beating Asteroids will allow you to have full control over your tables, full X,Y,Z everything
HOWEVER, if you want to adjust the ignition maps, you have to download Ms. Pac-Man (NOT ORIGINAL PAC-MAN, IT IS NOT COMPATIBLE) and go through the same process.
