Timing
Old Dec 13, 2006 | 06:01 PM
FubarI33t's Avatar
Timing
ok. I got the crank and 0 mark painted. But i can't get them to line up with the light. If i pull the dizzy adjust bolt. to make the makrs line up. it kind of runs like crap. For timing. Do you make it hit the 0 mark. or is a diff mark i am aiming for?
Old Dec 13, 2006 | 07:47 PM
0 means TDC (top dead center)... which is great when disassembling the engine, but not for driving. I believe the n/a engine should be 10-12 degrees below TDC.
Old Dec 13, 2006 | 08:15 PM
FubarI33t's Avatar
K thanks. cause i just can't make the timing hit 0. 10-12 i can do. thanks
Old Dec 14, 2006 | 02:40 AM
Actually on my n/a '82 280zx. It is 8 degrees below top dead center for timing. That is what it says under my hood.
Old Dec 14, 2006 | 04:51 AM
FubarI33t's Avatar
my sticker's are gone due to the fire the car had been in. and my books said to look at the sticker for timing degree's. Lot of good that does.
Old Dec 14, 2006 | 12:35 PM
If yours is an n/a like mine, it should be the same. 8 degress below TDC. Try it and see if it works. It worked great on mine, that is for sure.
sidneyam
Feb 21, 2011 05:51 PM
Datsun_Husky
Nov 17, 2010 05:48 AM
Fast240Z
May 25, 2005 11:13 PM
DoTheDrew888
Apr 10, 2005 01:12 AM
Zmedic
Jul 20, 2001 01:26 PM
