Speedo and tach not working
Old May 29, 2008 | 11:24 AM
mikesz's Avatar
I searched but, couldn't find the answer.My tach and speedo aren't working after i did my turbo swap.For the tach,there ar a couple of wires that were from my old n/a ignition harness that are pushed aside.I think one of them is blue.I'm not sure why mt speedo isn't working.
I did replace my 80 n/a tranny with an 83 n/a.I thought maybe i needed to change out the speedo gear.I have no clue to the both of my problems and any help would be greatly appreciated.
Old May 29, 2008 | 11:55 AM
I can't remember off the top of my head if that blue one is the tach lead, or if it's the black one. Have you tried re-connecting them? Do you have a Haynes manual? The wiring schematics are in there...
Was it ever working? Have you checked the speedo cable from one end to the other? If it gets kinked, it won't spin right.
Old May 29, 2008 | 12:07 PM
mikesz's Avatar
I haven't tried connecting the blue wire yet.I thought the yach wire went to the neg side of the coil.The speedo was working before i did my turbo swap.I'll check the cable again,later in the week.My car is over 40 miles away at our lake cottage.Thanks for your help on my last thread.
Old May 29, 2008 | 12:28 PM
last time i had to fudge around with the tach signal it was blue wires all the way
turbopuppy
Oct 9, 2011 02:03 PM
Mrmoose
Jan 27, 2011 12:00 PM
Comrade_Charlie
Sep 14, 2006 02:10 PM
pmr2000
Mar 14, 2006 09:49 AM
Heat Rave R
Jan 31, 2005 11:48 AM
