Sensor Light MIL
Old Apr 12, 2011 | 09:33 PM
Lupe's Avatar
Sensor Light MIL
For Some Reason My Mil light Indicates The Brake Light Malfunction And Battery Malfunction But All The Lights Work Fine And Battery Is New Car Starts And Runs IDK Whats Wrong Can Anyone Help...
Old Apr 12, 2011 | 10:56 PM
BlueKitsune's Avatar
Intrawebz Wizard
Have you checked the fluid level in your brake reservoir? And if you have an early ZX they came with non-maintenance free batteries from the factory that you had to check the fluid level every so often to make sure they didn't dry out. There should be a wire somewhere near the battery (or if your lucky the entire level sensor rod!) and just connect that to the +side of the battery. No more light!
Old Apr 13, 2011 | 11:58 AM
Lupe's Avatar
OK I Found The Cable And Connected It No More Battery But It Still Turn Red And Indicated Brake. When I First Turn It On It says OK But Then When I Press The Brakes It Turns On Brake Fluid Level Good>
Old Apr 13, 2011 | 12:16 PM
Intrawebz Wizard
Wait, I had a brain fart... There is no "Brake" light in the warning lamp system. http://xenons130.com/warninglamps.html You need to go check your tail lights and make sure the brake sides isn't corroded or damage and that the brake lights themselves actually work.
Old Apr 13, 2011 | 12:24 PM
What year is your car? As far as I know, there is no "BRAKE" warning in the square box... it is STOP like Blue said. There is a BRAKE light above for fluid / e-brake.
Old Apr 13, 2011 | 12:28 PM
Lupe's Avatar
HAHA Im an Idiot So I Checked My Taillights And There Was One Brake Light Lit Up On Both Sides So I Didn't Pay Much Attention Then I Checked My Other Z And I Realized It Had 2 On Each Side So Then I Checked My Bulbs And Both Of Them Were Burned So I Swapped Bulbs No More Light Now hah. Thanks For The Help BlueKitsune !!!!!!And Sorry I Did mean Stop I Guess My Brain Was Acting Al little Slow
Old Apr 13, 2011 | 12:31 PM
Intrawebz Wizard
Welcome! lol
cbaumy34
Apr 14, 2013 06:57 PM
Turbo86
Jan 15, 2007 03:45 PM
omniserv
15
Feb 27, 2006 04:24 PM
Customlock
Mar 29, 2003 11:51 AM
Z_Guy
Sep 17, 2002 11:27 PM
