rebuild kit where are you
Old Sep 29, 2012 | 01:18 PM
ricksilvia's Avatar
anyone know where a l28e rebuild kit is?
Old Sep 29, 2012 | 03:02 PM
Nissan OHC-6 173-2.8L Master Engine Rebuild Kit, 1975-1983 | eBay
Nissan Master Engine Rebuild Kits and engine rebuild kit | Parts
Import Performance Parts - Nissan HP Engine Kits
RaceTep
Old Sep 29, 2012 | 05:55 PM
If you want the best value for your money pick cost effective performance parts. I did a few posts on the "best" bang for your buck bits for a budget build (ITM hypereutectic pistons, ARP head and rod bolts, ITM gasket set, etc, etc).
Old Sep 30, 2012 | 12:01 PM
ricksilvia's Avatar
i guess im not quit rich enough for this haha stupid hobbies
Old Sep 30, 2012 | 12:04 PM
Maybe you could enlighten us on what you are attempting to do?
Does your motor need a FULL rebuild?
And yes... engine rebuilds are not cheap...
Old Sep 30, 2012 | 12:14 PM
ricksilvia's Avatar
well im around 170000 miles and im getting white smoke never at startup only after it warmed up and reved around 3k-4k+ I am assuming its the rings and since my intentions are a daily dependable drive i just assume rebuild the short block?
thanks
Old Sep 30, 2012 | 12:16 PM
White smoke means it's burning coolant (blown head gasket).
Blue smoke means it's burning oil (worn rings, or valve seals).
Black smoke means it's running rich.
A proper diagnosis can save you thousands of $$$.
Old Sep 30, 2012 | 12:19 PM
ricksilvia's Avatar
its definitely white.. simple as new head gasket? thanks for teaching me that btw..
Old Sep 30, 2012 | 12:20 PM
Head gaskets aren't "simple", but it is less complicated than an entire rebuild.
Start with reading the spark plugs and compression check.
Old Sep 30, 2012 | 12:22 PM
ricksilvia's Avatar
how did you learn all of this.. and i will go down to garage and do the test ill let u know the numbers?
Old Sep 30, 2012 | 12:25 PM
School, reading, researching, doing, working at a Nissan dealer, body shop, fixing and flipping cars... etc.
Old Sep 30, 2012 | 01:35 PM
ricksilvia's Avatar
1:151psi 2:147psi 3:155psi 4:150psi 5:150psi 6:145psi ????
Old Sep 30, 2012 | 01:57 PM
I'll one up nismo since a blown headgasket won't automatically equate to a loss in compression.
Check to see if you've lost coolant, with the engine warm put a coolant system pressure checker and pump it up and see if the pressure decreases and if that doesn't show anything connect it and run the engine and watch for a huge spike or decrease in pressure when the engine is revved up.
Old Sep 30, 2012 | 04:23 PM
^^^ Always gotta be a "one upper" eh?
Old Sep 30, 2012 | 05:30 PM
ricksilvia's Avatar
crazies hows the numbers look idk what the spec is? anyother tests i can run?
Old Sep 30, 2012 | 05:37 PM
*spanish guitar playing*
noelawinslow
Jun 19, 2013 07:45 AM
onerudebuddha
FS: 300ZX (90-96)
Sep 23, 2007 12:48 PM
snwbrderphat540
Mar 27, 2006 09:43 PM
91zxtt
Feb 2, 2004 04:02 PM
Tony G
Jul 22, 2003 12:54 PM
