Question on wiring
Old Jun 11, 2011 | 12:32 PM
garretthes's Avatar
Question on wiring
I have a problem with a short to ground when I crank the car. The car cranks and runs but it blows one of my 20 amp fuses I replaced the fuseable links with. I found that with the ignition ON the coil BW wire shorts to ground. I discovered that if I unplug the EFI relay the short goes away.
I have traced the problem to the green wires at the relay. After close inspection of the wiring diagram I noticed one of the G wires leaves the relay then goes to a connector. It appears to my untrained eyes this connector (under C3) connects the G wire to a BW wire.
Confused.
Old Jun 12, 2011 | 06:57 AM
dont try and understand the wiring on some of these parts, it will confuse you and drive you crazy. so if you unplugged the efi relay and it goes away, then there are i think 4 or 5 wires that leave it. if you have a short at the coil, try taking the wires off and testing there first, does it still short, if not, that eliminates those wires, they are just a byproduct of the symptom. next find out what wire goes where and unplug them, at some point the short will stop happening. it may be that efi relay is grounding out internally from moisture etc. most bw wires are +12v, the green g wires can are usually +12v as well.
Old Jun 12, 2011 | 02:41 PM
garretthes's Avatar
True but on the schematic the relay greens seem to be earth. Going to do more testing today
Old Jun 12, 2011 | 03:42 PM
garretthes's Avatar
Tested the yellow wire at the ignition switch and it's shorted to ground??? This wire is supposed to go strait to the starter
Old Jun 12, 2011 | 03:54 PM
garretthes's Avatar
Maybe I should ask if the 83 ignition switch is compatible to the 79? I swapped the ignition switch over because the 79 was damaged.
Old Jun 17, 2011 | 11:33 AM
Ignition switches should be the same. You can verify with the fsm for that year and the wiring diagram. www.xenons130.com
Old Jun 17, 2011 | 12:53 PM
garretthes's Avatar
Here was the problem. I had a former fusible link wire connected to a 20 amp fast blow fuse. Needed a 30 amp slow blow. The ground issue was a ruse. I was chasing my tail.
Old Jun 17, 2011 | 02:47 PM
Nothing like chasing tail however chasing your own tail is not quite a fun...
walton99
Mar 18, 2014 06:19 PM
Male
Mar 15, 2013 08:47 PM
Cap
Jun 14, 2012 08:24 PM
Edz280zx
May 12, 2011 11:00 AM
Switchtr3
Nov 27, 2010 11:41 AM
