poor take off
Old Apr 14, 2012 | 07:40 AM
trent_mcgee6's Avatar
poor take off
i got an 82 280zx NA. this is my first z so i honestly know very little about them.
when i go into first, everything is fine until i let the clutch completly out then it just has no take off power. like it take alot longer to get to a point where i can shift. its slow on take off in 1st, 2nd, and 3rd. the only way i can get it to accelerate faster is by going to a high rpm before letting the clutch out.
things i have done to it:
NGK-R plugs
compression test
NGK plug wires
New dizzy
dizzy cap and button
valve cover gasket
cleaned throttle body with carb cleaner
seafoam vaccum lines
clean k&n air filter
clean AFM
still didnt help.
additional info
the dizzy i got had a different electric box on the side as my original. i swapped the out after i found that that box wouldnt let the car go past 3500rpm.
im not sure if my distributer is turned right where it needs to be.
i but a bottle of lucas upper cylinder lubricant plus injector cleaner and it seemed to help but i could've imagined it
any ideas?
Old Apr 14, 2012 | 08:53 AM
ThaPimpShrimp's Avatar
So.. you haven't set your timing?
Old Apr 14, 2012 | 09:34 PM
no, i just set it in there and turned it till it sounded alright.
NismoPick
Other Cars
67
Dec 3, 2008 08:23 PM
Mhinrichs
Dec 5, 2007 06:35 PM
RPS13_GZ32
May 4, 2006 10:07 PM
apollo
Apr 24, 2006 08:33 PM
livewakesnow
Jun 24, 2005 05:45 PM
